Old 03-05-2016, 09:12 PM   #1
kchinth's Apex 288BHS Mods
We recently upgraded from a 2011 Coachmen Catalina 22FB to a 2016 Coachmen Apex 288BHS. It's too cold to camp, so I've been working on some modifications while the camper sits in the driveway.
First modification was to add the Progressive Industries EMS-HW30C. Pretty easy install. Just needed to remove the dinette cushion and cut the power wire.
2013 Ford F-150 EcoBoost
kchinth is offline   Reply With Quote
Old 03-05-2016, 09:16 PM   #2
Second mod was to add an outlet in the back storage compartment. This will allow me to charge my cordless drill battery for use on the stabilizers.
Old 03-05-2016, 09:18 PM   #3
Next mod was to add an LED light strip to the back storage compartment. You can see the light in the picture on the previous post.
Old 03-05-2016, 09:20 PM   #4
Next mod was to drill a hole in the propane knob to add a lock. Never had an issue with theft, but better to be safe.
Old 03-05-2016, 09:22 PM   #5
Next mod was to add a battery disconnect and battery lock. The battery lock is from B & D RV Battery Lock For RV travel trailers and popup campers.
I also ran a cable through the spare tire and locked it to the same padlock as the battery.
Old 03-05-2016, 09:30 PM   #6
Favorite mod so far, adding a propane quick connect outlet so I can hook up my Weber Q grill.
Luckily there was an open spot on the propane manifold under the camper. I used a propane hose with a 3/8" female flare fitting to connect to the manifold and a 1/4" MIP fitting to connect to the quick connect valve.
I mounted the quick connect under the side of the camper.
Closer view of the quick connect. I used a metal fence piece I found at Menards to mount the valve with some self-drilling screws. I also used a 3/4" pipe holder to keep it stable. It worked really well.
Old 03-08-2016, 10:56 PM   #7
Was the grill setup to us the1# tanks ? If so what did you have to do at its end ?
Doctarie is offline   Reply With Quote
Old 03-08-2016, 11:22 PM   #8
I go RV'ing not Camping
jgourlie's Avatar
Mods look good
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 03-09-2016, 09:59 AM   #9
Yes, the Weber Q has a regulator and is setup to use 1# tanks. It was pretty easy to modify
There are 2 screws that you need to remove and then you can unscrew the regulator. This leaves a 1/8" male thread.
You can attach this fitting:
Sioux Chief 1/4 in. x 1/8 in. Lead-Free Brass FIP x FIP Coupling-931-13100201 - The Home Depot
And then attach a quick connect fitting with 1/4" male threads:
http://amzn.com/B007HG7WUQ
This leaves you with a quick connect valve on the grill and you can buy a hose like this to connect the grill to the camper:
http://amzn.com/B00CPYC9BC
I also bought this hose and adapter so I can still connect the grill to a 1# tank or a 20# tank. This is handy for using the grill when we're not camping.
http://amzn.com/B0014JI6R0
http://amzn.com/B00480BWA0
Old 03-09-2016, 05:12 PM   #10
Ok thanks i thought they had a regulator for the one pounders . Thanks for the info !
Old 03-09-2016, 11:20 PM   #11
SeaDog's Avatar
I like the idea of the lock on the propane I'm going to do that thanks
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-10-2016, 07:44 AM   #12
KDHfan's Avatar
Congrats on the new rig. Here's a thread that has a few additional mods and info on the 288BHS.
http://www.forestriverforums.com/for...ad.php?t=68413
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 03-10-2016, 06:12 PM   #13
Jc furnace man's Avatar
A bit off topic but I saw in one of your pictures your Anderson wheel leavers. Have been thinking about getting a set are the worth the money?
Jc furnace man is offline   Reply With Quote
Old 03-10-2016, 08:54 PM   #14
I haven't really gotten a chance to use them camping yet. There are some other threads about them, and they seem to get positive reviews.
Old 03-20-2016, 08:18 AM   #15
Bama PrimeTime's Avatar
I don't want to steal your thread, But I've had my Anderson levelers for 3 years now and they are one of the best camping investments we've made.
Now back to our regularly scheduled topic!
John
Ted
Bama PrimeTime is offline   Reply With Quote
modifications
