Old 05-15-2015, 11:16 AM   #1
Captn.Ken's Avatar
Kobalt tool box
I saw a tool box mounted on the trailer tongue not long ago. The author of the post was "jpgowin" and he had bought the tool box at Lowes. I looked at Lowes website and other locations and could not find that same model. When I went to our local store I decided that the Kobalt box designed for pickup sides would fit nicely. It is 48 inches long and fit nicely, bolted to the frame. It has room for my batteries ( I am using two 6 volt golf cart batteries) and various tool boxes. And a tray for commonly used tools you want to keep handy. This mod uses some of the unused space between the gas tanks and the trailer body. These boxes weigh very little, and no heavy tools are stored here, so no concern about increased tongue weight.
ID:	77010   Click image for larger version
ID:	77011   Click image for larger version
ID:	77012   Click image for larger version
Captn.Ken is offline   Reply With Quote
Old 05-15-2015, 07:22 PM   #2
etothepii's Avatar
Very sweet setup! How much was the tool box?
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 05-15-2015, 09:26 PM   #3
Captn.Ken's Avatar
The box from lows is $169.00. If you have a Lowes card, you get 5% off. This box is built by "Better Built" company. They sell more sturdy versions on their website for $219.00. The Lowes box, labeled "Kobalt" is not real heavy duty but to store batteries it does just fine. I've seen similar size boxes on Internet for as low as $93. But, the shipping was $60.00! So, you're not really saving by ordering online with that type of freight deal.
For those who are interested, the trailer is a 2014 Surveyor SP220.
Old 05-25-2015, 10:32 AM   #4
Captn. Ken, how did you fasten the box to your frame? Thanks.
geokolb is offline   Reply With Quote
Old 05-25-2015, 07:21 PM   #5
Captn.Ken's Avatar
I set the box on the tongue in the exact position I wanted. Make sure the top of box will clear trailer front when you open it. Then, with box in place, I ran a magic marker under the box, along side the trailer frame. This showed me the area where I needed to put my fasteners. I drilled holes in the bottom of the box and put it back on the frame in position. I then ran a drill bit through the holes in the bottom of the box to mark the spot I needed a hole in the frame. Then I drilled through the frame material (don't do this if you have wiring running through your trailer frame). I set the box back on the frame, lined up the holes, and used four self tapping screws on each side (these screws were included with the box). That's a total of eight screws into the trailer frame. It won't come off any time soon. I hope this explanation makes sense.
Old 05-25-2015, 09:16 PM   #6
Kobalt Tool Box
Thanks very much for the detailed explanation. I am about to do the same thing with my Cherokee Grey Wolf 26RL which has about the same amount of room between the propane tanks and the camper front. Thanks for the heads up about making sure the lid can open freely with out interference. I live in Phoenix, AZ and I'll be venting the box to allow for air circulation to avoid overheating the batteries. I also plan on installing a 10 watt solar panel to keep the batteries topped off. Very informative, thanks again, George
Old 05-25-2015, 09:31 PM   #7
Captn.Ken's Avatar
Glad I could help someone. This box has been a really good thing to have. I can keep my most commonly used tools in the tray and plenty of room for batteries and tool boxes. Happy travels with your Grey Wolf.
Old 05-27-2015, 05:14 AM   #8
brownie289's Avatar
I have a simiilar set up, with only one battery. I keep dirty stuff in it when not towing. (Weight distribution bars, anti-sway bars)
Also my grease gun lives there.
It's nice to be able to lock up my battery but I never have.
Db
2015-26days, 2014-32days,
2013-33days, 2012-30days
brownie289 is offline   Reply With Quote
Old 05-27-2015, 06:09 AM   #9
RSchleder's Avatar
Just wondering, should the "box" be vented due to batteries being stored/placed in it??
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-27-2015, 06:16 AM   #10
brownie289's Avatar
Probably yes...but mine isn't. I have had the same box/set up on two campers since
2006 and haven't noticed any corrosion or other issues.
Db
Old 05-27-2015, 10:41 AM   #11
bpa098's Avatar
How does it go? Measure twice cut once? I bought a box on craigslist and it won't fit. Back to my search and posting this one back on craigslist lol. I want mine to be a little bigger to hold my grill, only place in camper it will fit is the pass through storage area, but doesn't fit through outside access. Have to remove dinette cushion and ply wood and still it's tricky to get in there. Don't want the grease in there.
bpa098 is offline   Reply With Quote
Old 05-27-2015, 05:18 PM   #12
brownie289's Avatar
For what it's worth I keep my grill in the pass through, in its bag (lined w a trash bag)
No issues so far.
Old 05-27-2015, 07:39 PM   #13
bpa098's Avatar
Brownie.... was even thinking about a tote to put it in. Love this new camper just doesn't have as much storage as I would like. Couldn't pass up the price though. It just has one big pass through that I'm trying to organize but seems like I have to take every thing out just to get one thing I need. In time I'll keep improving it
Old 05-31-2015, 08:42 PM   #14
I attached this Kobalt box to my travel trailer. I squeezed it in between my ProPride hitch jacks and front of camper. I attached it to frame with some U bolts, so I didn't have to drill into my frame Click image for larger version
Name:	ImageUploadedByForest River Forums1433122934.145329.jpg
ID:	78661Click image for larger version
Name:	ImageUploadedByForest River Forums1433122947.313337.jpg
LSUTiger is offline   Reply With Quote
Old 06-03-2015, 09:43 AM   #15
I had the same problem with the storage, but I solved it with a sliding tray. I built it using 8' garage door rails and rollers.
EYEMAN is offline   Reply With Quote
Old 06-03-2015, 11:38 AM   #16
bpa098's Avatar
That is a great idea. I might have to plan on something like that.
Old 06-03-2015, 01:21 PM   #17
Who Dares, Wins
doc73's Avatar
Everytime I log on here I get more to the list of mods.. Battery box.. Now a slide for the compartment! ARG!!
2015 Chevy HD D-Max
2022 Impression 315MB
Old 06-03-2015, 01:33 PM   #18
That's the fun in it doc73. I have made over 30 mods to our Avenger 27BBS and still counting. From Ground Control remote leveling to a fireplace. If it makes it more comfortable and convienent then I'm for it.
Old 06-03-2015, 06:52 PM   #19
Eye man,
You have a picture of how the rollers are set up to roll on those tracks?
Old 06-03-2015, 09:18 PM   #20
Originally Posted by LSUTiger View Post
Eye man,
No picture, but I'll try to describe. I built a stationary frame of 2x4s. One 2x4 on each side of the tray, both resting on 3 cross member 2x4s laying flat. The rollers (4 on each side) are mounted on the inside of the side rails by driving the shafts of the wheels into the 2x4s with clearance for the wheels to turn freely. The tray will slide out from either side of the trailer with stops to keep it from coming out too far. I also put dead bolt latches on each side side of the frame end to lock it in place to keep it from moving within the closed doors. Hope this helps, but let me know if this is confusing.
