Old 08-20-2015, 07:38 AM   #1
arutlosjr11's Avatar
Ladder/ Bunk Mod
Seems like a simple fix, but my Rockwood 2504S TT did not come with hooks at the end of my son's bunk ladder.
As is, the ladder can slide right off, taking him with it.
Any suggestions or easy fix ideas would be greatly appreciated.
arutlosjr11 is offline   Reply With Quote
Old 08-20-2015, 08:14 AM   #2
cdangel0's Avatar
Teach him how to tuck & roll??
How about rubber anti-skid pads on the ladder where it meets the bunk?
Craig & Lynn D'Angelo
cdangel0 is online now   Reply With Quote
Old 08-20-2015, 08:38 AM   #3
We have plans for children (but apparently children don't have plans for us, lol), so we bought a trailer with bunks, and so happened to purchase a 2504S. We have never used the bunks, but also noticed that there isn't anything to keep the ladder in place. One thought that I had was to tether the bottom of the ladder to the base of the cabinet under the bottom bunk. You could attach an eye bolt, and then attach a tether to each of the "feet" (creating sort of a triangle from each foot to the base of the cabinet). Then use a carabineer to quickly connect/disconnect the tether. Your tether options are whatever you decided you want to use. Obviously looks play a role, or maybe for you functionality trumps looks, personal preference I suppose. Could be a light weight chain, or rope, or create your own out of braided wire that has the plastic sheath around it... It wont keep the top of the ladder attached to the bunk, but I figure if the bottom cant "slide out" from underneath, you wont need to worry about the top. Just a suggestion
2015 Rockwood Mini Lite 2504S
2015 Ford F150 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 08-20-2015, 08:57 AM   #4
I had the same ladder and also notice the ladder was pretty flimsy. I bought a 60" metal ladder with metal hooks. It can be used up to 10 degrees so it was too long (typical for these ladders) but tubing cutters fixed that in 10 minutes. I sleep in the upper bunk so I can actually get a good night's sleep and feel a lot safer using the new ladder.
Brewhedd is offline   Reply With Quote
Old 08-20-2015, 09:00 AM   #5
Don't Camp Enough
Bunk bed ladder hooks can be found online, home improvement stores and some hardware stores.
'2016 Rockwood 8288WSA
'2010 Tundra
DSMURPHY is offline   Reply With Quote
Old 08-20-2015, 07:58 PM   #6
etothepii's Avatar
Bunk bed ladder
First time I've done a link like this on my phone. I hope it works ok. The OP of the thread shows his solution. I copied it, and it works great.
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 08-20-2015, 08:13 PM   #7
Seems like whatever you do, the ladder needs to be able to stay in place, yet rotate up somehow so the bottom bunk kid can get out in the middle of the night if need be.
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 08-20-2015, 08:16 PM   #8
I got rid of the ladder Bunkhouse mods
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
bunk, modifications
