Old 02-25-2012, 05:58 PM   #1
ladder install
Has anybody installed a rear ladder on a v lite . is there a particular style of ladder . And what do people use as far as gasket material to seal the holes that the bolts make
ptrenken is offline   Reply With Quote
Old 02-25-2012, 06:10 PM   #2
Dave_Monica's Avatar
Adding a ladder is a little more complicated than you think. The attachment points must be where there's blocking or backing plates in the exterior walls when manufactured. As it's an option on the V-Lite, you should be able to install the same ladder in the standard location. You'll need to get the exact location of the mounting points.
Dave
