Old 02-17-2013, 11:53 AM   #201
TURBS's Avatar
Originally Posted by DnD View Post
Or the drivers seat in the truck!!!!
Right!
Old 02-17-2013, 08:15 PM   #202
10x
DF has no clue of what I am up to. This is my way of getting away from the Honey Do list
10x is offline   Reply With Quote
Old 02-19-2013, 11:49 AM   #203
TURBS's Avatar
We do what we have to! !!!!!!
Old 04-04-2013, 08:30 PM   #204
LKicklight's Avatar
Gas Struts
Hay, have you thought of putting a gas strut on your front door? I would like to, along with a pair on the cargo door that does not have one from the factory....got any ideas?
Originally Posted by f1100turbo View Post
you MAY borrow it ! let me get some time on it to see if there's any bugs but I will report back .
I am going to run it in and out all week and see how it goes before I divulge any more info !
LKicklight is offline   Reply With Quote
Old 04-04-2013, 08:32 PM   #205
TURBS's Avatar
Kicker check with Old Coot as he has done this to his .
Old 04-04-2013, 10:14 PM   #206
Herk7769's Avatar
Lippert has a 10 pound strut on their web site. My camper came with a 20 pound strut and I had to remove it because it was destroying my door. The lock was binding; the top left of the door was hitting the frame and the hinges were being bent.
There is a thread here as well.
You can also see that in less than a year the piston had ripped the screws out of the frame.
Name:	Key West 2011 005.jpg
ID:	27093   Click image for larger version
Name:	Key West 2011 002.jpg
ID:	27094   Click image for larger version
Name:	Key West 2011 008.jpg
ID:	27095   Click image for larger version
Name:	Last Shots 042.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-04-2013, 11:08 PM   #207
MI Camperz
bodzcampers's Avatar
Awesome idea. You should patent it.
bodzcampers is offline   Reply With Quote
Old 04-05-2013, 06:04 AM   #208
LKicklight's Avatar
Door Strut
That is a shame...not much engineering going in huh..saw a unit at a recent show that looked pretty good...thought I would try the same..but if you have had this kind of problem, think I will pass..thanks
Old 04-05-2013, 06:39 AM   #209
I re-positioned both anchor points 2" closer to the hinge, pop riveted the door anchor and thru bolted the hinge anchor and it works great! Holds the door open over 90d and still misses the awning. Also helps close the door. We like it fine and no damage to anything.
Forest River Forums - OldCoot's Album: Door strut relocated
Old 04-07-2013, 07:43 PM   #210
The remote awning is great.Our Cherokee came with a remote for the awning and for the slide.The slide is real nice if you are close to something,u can stand out there and watch the slide so it does not hit a tree or something.Does make for ease with a beer in hand.
2012 Ram 2500 HD 5.7 Hemi
2013 Forest River Cherokee 254Q
SJones42 is offline   Reply With Quote
Old 04-08-2013, 02:33 AM   #211
LKicklight's Avatar
Awning Remote
Hey, I can only wish..we are just now getting use to the electric awning..having the manual one on the Sunnybrook, which we never use any longer, was a pain in the rear..especially on a windy day....I can wait for bigger and better things down the road...
Old 05-02-2013, 09:58 PM   #212
SYE
SYE's Avatar
Originally Posted by herk7769 View Post
I plan on installing mine with plan B.
With a double pole double throw switch in the lines; the switch will select the interior wall switch when flipped one way (thus function as a kill switch) and off the remote only when flipped the other way.
Both sides would be isolated from the awning motor and there would be no worry of a possible short circuit thereby letting all the smoke genies out of the module.
Ok Lou, I have got a question. I wired it up like this but I can not make it work. Was I supposed to use a different 12V source for both sources, it can I use the same source for both. It still works when the switch is set to the original awning switch, but will not work with the remote, possible a bad xmitter or remote is what I am thinking. Any input to this
Thanks Scott
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 05-02-2013, 10:01 PM   #213
You may not like the power one from the standpoint of you can't tie it down for windy conditions without poles of some kind. The operation of the power is great.
Old 05-03-2013, 05:41 AM   #214
Herk7769's Avatar
Thanks Scott
Scott,
Without a wiring diagram to show me how you hooked it up I can be of limited help.
Remember that you are switching the MOTOR lines not the power.
When the switch is in "CAMPER", power comes from the wall switch.
When the switch is in "REMOTE" power comes from the remote control's power source (mine is from a basement light).
Name:	12V DC 2-POLE REVERSIBLE MOMENTARY REMOTE KIT RM66 Circuit Diagram with switch.jpg
ID:	29506   Click image for larger version
Old 05-03-2013, 06:25 AM   #215
LKicklight's Avatar
Poles
Please explain to me what the poles purpose would be verses the old tie down method of rope and the screw in dirt anchors?thanks
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
Old 05-03-2013, 06:47 AM   #216
The power awning does not have a very sturdy arm going back to the camper and it is hinged in the middle and is anchored about 1/2 way down on the side of the camper as opposed to the telescoping leg that went to the bottom of the manual awning which could also be disconnected and set on the ground.
Forest River Forums - OldCoot's Album: Power Awning Tie Down (Self Storing)
Old 05-04-2013, 07:54 PM   #217
TURBS's Avatar
Anybody have there remotes apart yet?
My battery was low so I pulled mine apart.
Are you KIDDING ME another battery to keep on hand.
27a
Old 05-05-2013, 05:48 AM   #218
Herk7769's Avatar
I get my batteries here:
BatteryJunction.com Batteries, Battery Chargers, Flashlights, Solar Products & more!
http://www.batteryjunction.com/gp-27a-bp.html
GREAT deals on flashlights and solar too.
Herk
Old 05-06-2013, 06:44 AM   #219
SYE
SYE's Avatar
Scott,
Ill get you a drawing as soon as I can, we are on the road for the next 2 weeks and internet is difficult at times. Thanks Lou!!!
Scott & Vicki
2021 4 reserved
Old 05-06-2013, 01:42 PM   #220
LKicklight's Avatar
Awning Remote
How much of a problem is it to get a remote switch for my electric awning...All we have is the switch on the wall inside..having a remote outside would be great....
of yes, we have had 5" of rain since Saturday, you can come get yours back if you want it.....everything around here is waterlogged!!
Attachment 29604
27a
Attachment 29603
awning, power awning, remote, modifications
