Old 02-09-2013, 09:39 PM   #181
captbenjy's Avatar
Wish you were closer. We'd ice down the brew and get them done. Guess I need to open up the switch panel and see how much room I have. Guess we could mount it in the cabinet behind the panel if space were an issue. Don't know how it'd affect reception of remote though.
2013 Columbus 320RS "The Wonder Wagon"
2009 F-250 4WD (Tuned) "Black Beauty"
captbenjy is offline   Reply With Quote
Old 02-09-2013, 09:46 PM   #182
SYE
SYE's Avatar
I am loooking for a different place to put mine, I need to find out where the power cable goes out to the awning I think it is up in the front closet, I will look when I open it up in the spring. Inalso bought a LED light strip the will go under the steps that will be on dusk till dawn. I found that info on here as well, my lights came I mam just waiting on the switch. All for less than 25.00
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 02-16-2013, 02:20 PM   #183
10x
Can someone please post a simpler illustration showing how you wire the double pole double throw switch? I am a beginner at this electrical stuff.
10x is offline   Reply With Quote
Old 02-16-2013, 02:30 PM   #184
TURBS's Avatar
Herk7769 should have a diagram.
Hopefully he'll post it up.
Turbs
Old 02-16-2013, 03:06 PM   #185
Coops1's Avatar
This should work for him...
lazy man's power awning mod .
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 02-16-2013, 04:23 PM   #186
Herk7769's Avatar
There are six connections on the back of a DPDT switch. The midde two are "the load".
The "throw" connects the "common" pin to the pin opposite the throw.
This harder to explain than it should be. The one set of three in a row pins switch the "black" wire and the other set of three switch the "red" wire for each throw of the switch.
If you still have trouble, a test light will show you how the sitch works.
Name:	12V DC 2-POLE REVERSIBLE MOMENTARY REMOTE KIT RM66 Circuit Diagram with switch.jpg
HAM CALLSIGN - KC3FFW
Old 02-16-2013, 04:26 PM   #187
TURBS's Avatar
oh lou im disapointed that you dont have a wiring diagram in that pc of
yours shocked really !
Old 02-16-2013, 04:32 PM   #188
10x
So then the awning wires connect to the center posts of the switch? Am I correct?
Old 02-16-2013, 05:10 PM   #189
Herk7769's Avatar
Yes.
Make sure the two motor wires go to the two middle pins and the campers oem wires go to one side and the remote feeds go to the other.
It took an hour to upload 2 posts.
Fayetteville Koa has free Internet and they are upgrading their service.
They said it will rock by next month.
We shall see.
Old 02-16-2013, 05:13 PM   #190
TURBS's Avatar
Yes.
We shall see.
now I understand why !
awning, power awning, remote, modifications
