Old 03-20-2012, 05:58 PM   #31
TURBS's Avatar
This unit is only good for 10amps or less.
Heavier units are available but pricey
Old 03-20-2012, 06:00 PM   #32
Wanna Be Camper
SaskCampers's Avatar
Just bought my unit. Woohoo. Hats off to f1100turbo as that is one sweet mod. Gee I hope there are not too many of these at the Rally in Indiana.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-20-2012, 06:01 PM   #33
Herk7769's Avatar
Mine is one the way as well.
HAM CALLSIGN - KC3FFW
Old 03-20-2012, 06:03 PM   #34
hoffkm's Avatar
Just purchased this kit for myself for the same reason that Herk mentioned. I do not like blindly rolling out my awning as the switch in my Rockwood is located in a spot inside the trailer that I cannot see the outside from very well. Thanks Turbo for this excellent find!!
2011 Rockwood 2901SS Ultra Lite
2014 Chevy Silverado Z71---Hensley Arrow Hitch
my other toy---1969 Camaro 396 SS
hoffkm is offline   Reply With Quote
Old 03-20-2012, 06:18 PM   #35
Herk7769's Avatar
OK here is the wiring diagram.
I gather that the wall switch becomes redundant when the remote is installed.
Name:	12V DC 2-POLE REVERSIBLE MOMENTARY REMOTE KIT RM66 Circuit Diagram.jpg
ID:	11059   Click image for larger version
Name:	12V DC 2-POLE REVERSIBLE MOMENTARY REMOTE KIT RM66 pin out.jpg
Old 03-20-2012, 06:29 PM   #36
TURBS's Avatar
HEY all I forgot in all of my hay day of getting this out on the forum I mistakenly forgot to say that you cannot use the manual switch without putting diodes in line from the remote module outputs to the awning wires . SORRY !
Since you have to basically tee into the awning wires you don't want current to go back into the delay when using the manual rocker .
If you do use the manual rocker without them you'll just blow the awning fuse since the delay module outputs are grounded when not in use .
OR you can install a switch on both remote module outputs so that you can use rocker I think that would be a hassle.
I had plans to go to radio shack and pick some up this weekend and thats what reminded me that I may have not said anything .
Sorry for my ignorance of not mentioning this but I AM SURE no one has there module yet !
I just wanted everyone to be clear about the rocker .
Old 03-20-2012, 06:30 PM   #37
TURBS's Avatar
lol HERK !
yes you cannot use it per my post 36 sorry
I was typing it up as you posted
Old 03-20-2012, 06:34 PM   #38
Being the electrical dummy that I am, I will probably just disable the rocker switch as I know absolutely nothing about diodes and how to use them, let alone which direction they have to be installed.
Old 03-20-2012, 06:38 PM   #39
TURBS's Avatar
had the awning out 6 more times tonight and no issues .
LOL the only issue I may have is a worn out motor by time I get done testing this thing !
the only other thing I changed tonight was to not use there 2 amp fuse but opted for a 7.5
reason being is the motor uses a little over two amp which is ok but when you dead head the awing either deploying or retracting the amperage will blow a 2 amp so I figure .
Old 03-20-2012, 07:13 PM   #40
Herk7769's Avatar
I would also install a "disable" switch in the battery line.
Driving down the highway and sitting on the fob could be problematic.
awning, power awning, remote, modifications
