05-06-2013, 02:03 PM
#221
Originally Posted by LKicklight
How much of a problem is it to get a remote switch for my electric awning...All we have is the switch on the wall inside..having a remote outside would be great....
of yes, we have had 5" of rain since Saturday, you can come get yours back if you want it.....everything around here is waterlogged!!
Done want it back kicker!
Easy job to install awning remote.
05-06-2013, 02:23 PM
#222
Remote
well then, turn me loose in the Radio Shack Store for what I need...
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
05-06-2013, 03:29 PM
#223
Pm sent kicker.
05-10-2013, 11:44 AM
#224
Sounds like a great mod. Fortunately mine came from the factory like this. Remote includes awning, slide out, stabilizer jacks and porch light. I guess I assumed everybody else's did too. I especially like being able to be outside when extending and retracting the awning.
05-13-2013, 06:34 AM
#225
Originally Posted by OldCoot
The power awning does not have a very sturdy arm going back to the camper and it is hinged in the middle and is anchored about 1/2 way down on the side of the camper as opposed to the telescoping leg that went to the bottom of the manual awning which could also be disconnected and set on the ground.
Forest River Forums - OldCoot's Album: Power Awning Tie Down (Self Storing)
I wish I would not be procrastinating so much, I thought my awning was going to rip off the wind caught it and it went almost vertical. I need to get my poles done and fast because these new awnings are made like a piece of tin foil....
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
05-13-2013, 06:37 AM
#226
I think you might have RVChicky's problem with posting pics. The poles only take about 30 minutes to install and you don't even need a ladder.
05-13-2013, 07:01 AM
#227
I need a ladder I am vertically challenged!!!
Scott & Vicki
2021 4 reserved
05-13-2013, 07:04 AM
#228
Deploy the awning and pull it down and tighten the arms in the down position.
06-19-2013, 01:10 AM
#229
Hi Friends,
I started following this thread when it was first posted some time ago. I thought this was a great idea and wanted to do this mod as well. My problem was that I don't use eBay and thought I was out of luck with this mod until I signed up. Well I figured out a way around it. I happened to be in Harbor Freight the other day and they had a remote on sale for a electric winch. It was 24 dollars. Someone on their website had taken the plug apart and discovered that the 5 pin plug was misleading as it contained 4 wires and the antenna wire. I will be in the process of wiring this in over the next few weeks when I get more time. The remote is good for 50 feet. I will order a direct response kit for the awning which rolls it up if it gets too windy. The kit comes with a dual switch so I can wire in a cut off switch.. I'll let you know how it goes.
Richard
06-19-2013, 05:57 AM
#230
Super !
Let us know how it goes!
06-20-2013, 06:22 PM
#231
Ok I finished my Remote control install for the awning today. It works great with the 1 thing. I have to be no farther than 6 feet from the 5er or it will not work. It might be because I had to mount it behind the control panel inside the door, or the battery, a number 27, could be low in voltage. Any suggestions, how far can you that have put these in control the awning. I mean it will work rfor what I wanted it for but I am just sayin!! I will try to post the video of it later tonight when I get home from work once I figure out how.
Scott & Vicki
2021 4 reserved
06-20-2013, 06:23 PM
#232
And to answer a question that I had from about a month ago, the remote was bad and they sent me a new one, this one works.
Scott & Vicki
2021 4 reserved
06-21-2013, 10:28 AM
#233
Here is the link to the video, it was too large to post on the forum.
Scott & Vicki
2021 4 reserved
06-21-2013, 10:57 AM
#234
Like the poles too! Just don't fold the grab rail over the awning rail like someone did on this forum AND then blame it on the poles. Not to mention any names, but the initials are Daisy Boykin.
06-21-2013, 10:58 AM
#235
Like the poles too! Just don't fold the grab rail over the awning rail like someone did on this forum. Not to mention any names, but the initials are Daisy Boykin.
No names noted!!!
Scott & Vicki
2021 4 reserved
06-21-2013, 11:03 AM
#236
No names noted!!!
Wouldn't think of it. That person should remain anonymous, right Sid?
09-03-2013, 02:04 PM
#237
Does anyone have more detailed instructions on where to mount the control unit?
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
09-03-2013, 02:23 PM
#238
Most have mounted it behind the control panel where the factory awning switch is.
Turbs
09-03-2013, 03:41 PM
#239
Turbs... Just when I think you can't get any dumber, you go and do something like this!
AND TOTALLY REDEEM YOURSELF!!!
I found myself shaking my head at this and I'm not 100% sure why...
It may be due to the fact that I find it stupid... I may find it lazy... I may find it pointless...
Ultimately I am feeling that I am shaking my head because I didn't think of this first and am incredibly jealous I don't currently have this installed on mine!
Nice work Turbs! Yet to be bored with you!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
09-03-2013, 06:26 PM
#240
Turbs
Thank you, however I mean more specific instructions? Anyone have the details on hooking up the wiring? I should've been more detailed in my question too.
