Old 04-22-2012, 05:54 PM   #1
Brigitte
boubou's Avatar
LCD TV bracket
So we got the bracket installed for the 32 inch LCD TV going into trailer. Photo to come soon
I'd like to know how you all secure the TV on the bracket to prevent it from moving side to side during travels.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 04-22-2012, 07:29 PM   #2
kz08h5's Avatar
The TV bracket I installed had a hook on the bottom. I used a nylon web strap to secure the TV. If the mount does not have any accommodation to attach a strap you could screw each end of a strap to the wall to which the mount is attached, ie find a stud. The may thing is to keep the TV from swinging out and becoming a long lever that will pry itself from the wall.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 04-23-2012, 12:17 PM   #3
Firstly, I am assuming that you have attached the mount securely to the wall. Gotta be attached to studs or from ceiling joists (as applicable). If you've got a 32" TV, that's a lot of weight including the mount.
Most RV manufacturers are using oridinary 1" velcro straps (one on each side of TV). The straps are attached to the wall with brackets. I bought plastic ones from www.theclip.com. The clips should obviously be attached into something solid like a cabinet wall or studs.
The straps on our TV mount are in these photos. Cheap solution and works like a hot darn.
Name:	050 (640x479).jpg
ID:	12616   Click image for larger version
Name:	048 (640x479).jpg
myredracer is offline   Reply With Quote
Old 04-23-2012, 12:36 PM   #4
Brigitte
boubou's Avatar
The mount is secured in a stud which was indicated on wall with a sticker saying "mount tv here).
I'll look for the strap, thanks
Superglide 2700
Timbrens
Old 04-23-2012, 12:39 PM   #5
Brigitte
boubou's Avatar
These clips are pretty much was i was looking for. I've been scouring hardware store looking for a little bracket into which I could just put the strap through. Thanks for the tip.
Superglide 2700
Timbrens
