Old 06-14-2011, 09:15 PM   #101
could you use small crimp connectors?
timorr98 is offline   Reply With Quote
Old 06-15-2011, 02:32 PM   #102
Just received my LED's from superbrite so far I like what I see. I wont be able to install them on the TT until the 27th but here are some pics of a quick test I did.
Here is the darkest area I could find.
Here is the WLED-WWHP6-TAC
Here is the WLED-WWHP10-DAC
I'll follow up once they are installed.
KoolAide is offline   Reply With Quote
Old 07-09-2011, 02:19 PM   #103
Great Lakes's Avatar
Just installed 11 LED's purchased from Superbriteleds.com. I used four warm white HP10-DAC bulbs in the overhead fixtures, two HP6-D bulbs over the table, and five 921-WW12's in the RV's remaining fixtures. Tonight, we'll see if everything is bright enough.
The first picture shows a ceiling fixture with a stock 921 on the left, and the 10 element LED on the right. The second picture has a 6 element LED on the left, & 10 element on the right.
__________________________________
Tom T.
2011 - 2104 Mini-Lite
ID:	6737   Click image for larger version
Great Lakes is offline   Reply With Quote
Old 07-09-2011, 04:14 PM   #104
Herk7769's Avatar
I found the 36 LED pads the correct size for us, although some have had good luck with 24 LED pads. You are the first to test smaller units.
HAM CALLSIGN - KC3FFW
Old 07-10-2011, 10:45 AM   #105
The new lighting scheme was mostly successful, but Linda wants more light in the bathroom. Just ordered some of the 36 LED pads, and plan to try them in the main overhead fixtures & relocate the 10 element units to the bathroom. Now I just have to wait for the slow boat from China for delivery.
Tom T.
Old 07-17-2011, 03:10 PM   #106
Flagstaff 625D Popup
I just upgraded the six 921 bulbs in my 625D pop-up to these:
LED 6 CHIP 921 REPLACEMENT RV BULB | eBay
I puchased these because they have the circuitry to drive the LED bulbs properly with a constant current. These gives longer LED life, better reliabilty and constant brightness as the battery voltage changes.
Installation couldn't have been simplier, slide the lens off, pull the 921 bulb, push in the LED replacement, slide the lens back on.
To my eye the LED replacements are not quite as bright as the bulbs. But the bulbs look really orange-yellow compared to the white of the LEDs.
The main reason I changed to LED was that if we had two of the lights on and turned on the third the other two would dim because of the current draw. Now that doesn't happen.
Overall I am very happy with these LED replacements.
Bean
bean is offline   Reply With Quote
Old 07-25-2011, 06:59 PM   #107
Replaced mine with the 36 LED units. I went with "warm white" as I can't stand the bluish tint of regular bright white LEDs. I'm very happy with the results. My current measurements show them to draw about one-third the current compared to the incandescent bulbs. I just ordered some single T10 LED replacements for my two reading lamps over the couch. I'll report on those when I have them.
Here are the 36 LED units:
Warm White Light Lamp Panel 36 SMD LED+T10+Dome+BA9S Ad | eBay
Here are the singles:
2 X T10 8 LED SMD Car Bulb Wedge Side Light Lamp White | eBay
03 Chevrolet Silverado 1500, 5.3 V8, 3.73
06 Rockwood Roo 23SS
Equalizer Hitch
dlhoppe is offline   Reply With Quote
Old 07-25-2011, 07:34 PM   #108
My 36 element LED's also just arrived, & I installed them in main overhead fixtures. Looks like we'll have plenty of light now.
I relocated the 10 element units to the bathroom and table fixtures, and the 6 element units are now over the sink and exhaust hood (tight fit!). Our next trip is next month, so we'll see how everything works then.
Tom T.
Old 07-25-2011, 07:57 PM   #109
Dismember
TimeFurnace's Avatar
Originally Posted by dlhoppe View Post
I confess I am losing lock on the ebb and flow of this thread. The link you show for the 36 LED units states that they come with various bases. Are any of those bases compatible with existing fixtures or did you have to splice or otherwise kluge up a connection? All of the posts about conductive epoxy have me a bit confused.
TimeFurnace is offline   Reply With Quote
Old 07-25-2011, 08:45 PM   #110
TimeFurnace,
The white "wedge" connector (T10/921) shown in the photo fits my fixtures. Not sure what you have in your RV though. The only thing I had to do to secure it was put a piece of double-sided foam tape on the back to stick it to the metal reflector in the fixture. Takes a few minutes to do each one. Very simple.
Equalizer Hitch
12 volt
