Old 03-30-2016, 05:26 PM   #11
Here is the kind of dimmer you need. Not sure if this one is big enough for the light strip but the concept is there. Search auto LED dimmer. They are used to common and inaccessible grounds. MODULE, DIMMING CONTROL, FOR USE WITH LED LIT GAUGES (UP TO 6)
You can also hunt down the negative lead for the light strip and use a cheaper one if you can find it.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 03-31-2016, 08:35 AM   #12
I traced the wires where they exited the trailer and they were easily accessible inside the front outside storage hatch. That is where I mounted my dimmer which required cutting both positive and negative wires and placing inline. The dimmer I got from Amazon has a remote control that I keep on my keyring. It works great.
Dimmer at Amazon
mjbenedict is offline   Reply With Quote
Old 03-31-2016, 08:38 AM   #13
rsdata's Avatar
specialty LED products...
call them
DIMMER-WP3 Wireless Control Panel and LED Dimmer Module - M4 Products
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 03-31-2016, 10:59 AM   #14
BBQ'er
D Casten's Avatar
Dimmer at Amazon
Thanks all for comments. Had not thought about mounting it up where both wires are ...Mount it up there and get one with a remote and velcrow it inside.
again thanks all.
I never saw or heard of a man being shot while cleaning the house.
D Casten is offline   Reply With Quote
led
