01-31-2019, 07:52 PM
WV Rambler
LED Dimming solution story
Hello all,
Recently I bought a Surveyor and noticed that both the interior and awning LEDs were bright enough to be unusable in certain situations, like night... when you need to use them.
The interior lights made watching TV at night painful, and the awning lights were bright enough that i felt they would be a nuisance to the next camper in closer quarters.
I read a lot online and found many who had suggestions with varying degrees of success. Thought I would share my success story.
Found a great dimmer on Amazon, and although not cheap ($30), it works PERFECTLY on both the interior and awning LEDS, and it is clean and simple looking. To be clear, I purchased two separate switches, one for each set of lights, and wired them inline with the existing factory switch. I mounted the rotary knobs above the existing panel by drilling two small holes in the paneling, and I think they look as good as they work. There is a simple install where you wire two wires to the load and one to the line, and as long as you get the polarity correct the dimmer functions perfectly. This switch even has a full off-click position, so it can be used exclusively to control the lights. I prefer to leave the dimmer on, and use the original switch to toggle on/off.
Here is a link to the switch.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It is rated for up to 4.2A of draw. I measured and the inside and outside leds were each drawing less than 2A so this switch worked great. Can't upload the video of them working, but here is a shot of the install. I purchased the "long shank" version, and the locking nut had plenty of room to secure it to the panel.
The switches are more expensive than most, but the company is VERY responsive online and claims to use a "true pulse width modulated" process which gives a full dimming capability and has no flickering. I can attest that it works well.
PIC OF INSTALL - KNOB ON LEFT IS FOR INTERIOR LIGHTS, KNOB ON RIGHT IS FOR AWNING LIGHTS:
Dirk
2018 Surveyor 287BHSS
2006 GMC Sierra 1500
01-31-2019, 08:07 PM
Great idea and looks good!!
01-31-2019, 08:34 PM
I have tried this before but don't have access to the ground. Did you wire with the ground or did you only wire the + side of the light?
01-31-2019, 08:38 PM
Looks nice. Thanks for sharing!
01-31-2019, 10:54 PM
Here's what I bought. $29.95. Comes in white, black or brown. Though you do need a neutral/ground.
2013 Georgetown XL 378
2008 Honda CR-V
01-31-2019, 11:24 PM
WV Rambler
Just in line on the positive wire. The switch documentation gives you a method to run inline without a ground. On our coach there is a fuse on the positive leg already, so I spliced it in after that so it would still be functional and blow should there be any problems.
02-01-2019, 09:11 AM
Originally Posted by kraushad
Hello all,
If it helps what I did was to find a neutral on the control panel next to where I installed my switch.
I always thought that a PWM dimmer must be installed for led's or they will heat up and PWM's have grounds. Though there may be new devices on the market now.
Do your dimmers have 3 wires or 2?
2008 Honda CR-V
02-01-2019, 09:28 AM
That is what I used, inline with the existing factory switch:
No flickerin, works perfect!
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - Sep 2021
Entegra 27A Oct 2021 - ?
02-01-2019, 01:39 PM
Hello all,
I have but one word so say about your idea and your installation.................SWEET!!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
02-01-2019, 01:41 PM
This is just what I have been looking for.
Now I can dim the LED lights on my 2019 Heritage Glen.
Thanks.
02-01-2019, 01:42 PM
Dahagen
Originally Posted by Loefflerh
X2 on these.
02-01-2019, 01:49 PM
If you don't mind just having the circuitry exposed, you can save some money and just use something like this:
https://www.ebay.com/itm/6V-90V-15A-...PlvU:rk:3:pf:0
Way cheaper than $30.
There are a lot of these around. That's just one example. I have a couple I use on my boat for its LED lights. Going to mount one to control my stove hood fan too.
02-01-2019, 01:51 PM
I used this item as well and it works great. The only caveat with these is you need a clean ground. In my installation the builder had combined multiple grounds so it dimmed every item on the ground including my AM/FM stereo. I had to run a new ground.
02-01-2019, 01:53 PM
Sounds like something was wired incorrectly. Should be no problem having multiple grounds as long as the ground can carry all the current without voltage drop.
02-01-2019, 03:21 PM
WV Rambler
It is a three wire, however the instructions include a method for combining the red/white in case of no ground usage. If you follow the link in my OP, you can see the pic on Amazon of the wiring diagram on the package.
Not sure how PWM works, but the simple install works.
02-01-2019, 05:52 PM
I have those and the one I installed does NOT work. Not sure what to do. Haven't been able to spend much time on the issue.....
02-01-2019, 09:49 PM
Thanks kraushad, I learn something new everyday. The earlier dimmers use to heat up the LEDs to a point of overload and burnout. They must have improved them. Enjoy your new dimmers, they sure make it easier on ther eyes in the evening.
2008 Honda CR-V
02-02-2019, 09:05 AM
I have these. The problem I have with them is that when I first turn on the battery to the trailer the lights come on automatically. If I don’t remember to turn them off it will drain the batt. Any of you have this problem?
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
02-02-2019, 09:27 AM
I put a dimmer on mine as well for $2.29
2019.5 Rockwood 2509S
02-02-2019, 10:27 AM
Sounds like your multiple grounds are actually above ground. Check with your volt meter (positive lead) from the wires going to ground and the negative lead to ground structure and see if you get a voltage reading (should be "0" volts). If you do get a voltage reading you have a poor grounded connection.
