Old 12-14-2015, 05:46 PM   #1
LED mounting channels
Looking for a channel or something that I can mount to the underside of the awning that I can slide the LED strips into.
I know I just stick them on the side and be done, but if there is an issue or I want to change them I can just slide them out of the channel. Also didn't want them firing straight out or down. Maybe on an angle.
The ones I have seen are only about 3 feet long so I would need 7 to go the length of the awning.
AGFazio is offline   Reply With Quote
Old 12-14-2015, 06:01 PM   #2
Wobbles's Avatar
Check out Dometic, they have just announced something called "Power Channel". I have no experience with it and it's new, so do your research.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 12-14-2015, 06:06 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
A couple of years ago I bought a system at Camping World that had plastic channels that slid into the awning roller slot. Then you inserted the rope LED light. Came in 18 ft length. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 12-14-2015, 08:57 PM   #4
Might find something here. This is a good place to start. I use the RGB LEDs from here also with an RF remote.
http://www.amazon.com/LEDwholesalers...JN3A03SXCA7CRY
2002 GMC 2500HD
2016 Crusader 294RLT
JoeFon is offline   Reply With Quote
Old 12-15-2015, 06:32 AM   #5
cpaulsen's Avatar
I just used the plastic ones from HD......only 3 feet long but have worked just fine.
cpaulsen is offline   Reply With Quote
led, mount
