Old 03-06-2015, 11:26 AM   #21
The up/down controller will use a PWM (pulse width modulation) to adjust the brightness of the LED's. Using a potentiometer will only work on dumb led's. If the led has a constant current source built in then the brightness will not change till you drop the voltage very low.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-06-2015, 11:27 AM   #22
Ah, ok, voltage regulator, I thought you were working with a dc/dc converter. Maybe all you need to do is wire in a bypass switch so if your battery voltage gets too low for the regulator you can apply full available voltage to the lights.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 03-06-2015, 11:32 AM   #23
All of the dc led replacement lights I've seen are "dumb", just groups of component leds in series and parallel groupings on the board to get them to the right voltage. Downside is when one component led goes then the whole group goes and you get a dead spot.
2010 Chevy Suburban
Old 03-06-2015, 11:35 AM   #24
It is the same with the constant current ones. They put the led's in series and if you lose one you lose the whole string.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
led, replacement
