Old 07-02-2016, 01:56 PM   #1
dcheatwood's Avatar
LED strip install advice
Just bought a led strip for under the awning. Wanted to see if some of you can help me avoid some mounting mistakes you may have made. Awning is 12'+. Strip is 16'.
I'm attaching pics of awning area and led components.
I have exterior lights near left end of awning and power to awning motor in rail on right end of awning. Where to tap 12v??🤔
All advice is appreciated.
ID:	112847   Click image for larger version
ID:	112848   Click image for larger version
ID:	112849   Click image for larger version
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-03-2016, 08:32 AM   #2
Power to awning motor is switched so that won't work unless lights on roller was an unused option. I tapped into power feeding the light in my pass through on my old sob trailer, new lights we just installed are 24 volt so have to plug them in at out side TV power.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 07-03-2016, 12:03 PM   #3
edgewant's Avatar
I had one these led strips attached to the bottom of my slide out awning. Unfortunately after about 1 yr the copper in the strip ate through the adhesive strip due to a galvanic reaction and damaged the aluminum cover on the awning. I'm now leary of replacing them. Will either have to replace or repaint the cover.
2013 Berkshire 390RB-60
Toad: 2002 Jeep Wrangler
edgewant
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 07-03-2016, 12:22 PM   #4
Flybob's Avatar
The adhesive on those strips is not the highest quality. Save some aggravation later by using 3M auto trim tape to mount. Stick the strip to one side of the 3m tape and then stick the 3m tape to the trailer.
The controller should go inside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-03-2016, 12:37 PM   #5
edgewant's Avatar
Not for me. I'm done with them 2 strips in one year and corrosion ain't worth it. Cheap stuff that leads to bigger problems.
edgewant
Old 07-03-2016, 12:49 PM   #6
rsdata's Avatar
on my original lights on my Shamrock, the lights were installed in a plastic U channel, which was just a press fit, no adhesive involved for the LED strip, except for the U channel to the trailer. I would try to find that U channel at a Home Depot or online. I would tap 12 V on the inside and install the controller inside by the door, then string power wires above the U channel to either front or back. Many strips can be cut to length and are marked so on the back of the strip.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 07-03-2016, 01:01 PM   #7
dcheatwood's Avatar
Some good warnings and advice. I'm gonna research this a little more before starting.
I thought about the awning power being off unless activated after I posted. Duh. Controller inside, good idea. Thanks. 3M tape is good too.
Old 07-03-2016, 01:10 PM   #8
Gut the "Scare Light" on the left side between the speakers! Now you have a On/Off power source and a Dry place for the control! You will not miss the few " of lighting strip you cut off! And you sure will NOT miss the "Scare Light" under the Awning,can we say Super BUG Attraction! Youroo!!
ID:	112927   Click image for larger version
Old 07-03-2016, 01:50 PM   #9
dcheatwood's Avatar
Thanks youroo. I had read that somewhere but couldn't find it again. And, since there is a white and yellow light on the left, I figured i could without one of them. I've been leaning that way but concerned about the exposed wire from led to scare light.
Yours look good.
Old 07-04-2016, 01:39 PM   #10
I wired mine into the Amber "patio" light enclosure and used double faced sticky cable molding with a 90 elbow connector I found at Lowes.
Shop Mono-Systems, Inc. 0.5-in x 192-in White Cord Cover at Lowes.com
I also added a switch to the patio light enclosure so that I could power that down when I just want the LEDs on which in my case was easy to reach from the door.
I used RTV Silicone to help hold the LED strip and the cable molding. It's been on for 2 yrs and counting.
ID:	113069 Click image for larger version
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
led
