Old 04-05-2015, 08:11 PM   #1
Alberta8311ss's Avatar
Led strip light in pantry
Well, no more dark pantry! Let the midnight snacking begin😎
Just about need sun glasses when I look in there.Click image for larger version
Name:	ImageUploadedByForest River Forums1428282516.351364.jpg
ID:	73179Click image for larger version
Name:	ImageUploadedByForest River Forums1428282538.573406.jpg
Well maybe after it gets loaded up with something worth eating, them garbage bags leave lots to be desired.
Put a door switch on to have it come on automatically. I'll probably paint it to match or pick up a brown magnet.
Rockwood 8311ss
Pro Pride 3P hitch
Alberta8311ss is offline   Reply With Quote
Old 04-05-2015, 08:28 PM   #2
vinmaker's Avatar
What a great idea. I think I will look into putting some under my dinette. that storage area is always dark and hard to find things.
They are simple 12V wires right? Just figure out a way to run a wire off the battery?
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 04-05-2015, 08:43 PM   #3
Yes 12v so no adapter needed. There was no constant 12v under the pantry so I had to fish a wire to the led interior light that was 2 feet away. Went ok as the styrofoam insulation had a wiring raceway I could use. The LED ribbon is warm white and the type was a 5630 chip. These are the nicest/warmest 12v ones I have ever bought.
Rockwood 8311ss
Pro Pride 3P hitch
Old 04-05-2015, 09:02 PM   #4
HONDAMAN174's Avatar
Yep I agree it's a great idea. I've been planning that upgrade for a few weeks now and been waiting for and item or two to come in.
Did you run the lights on both sides or just one?
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 04-05-2015, 09:13 PM   #5
I Just put them on the one side that had an edge to hide them (hinged). I had to get power out of the ceiling unless I wanted them on the outside scare light or water pump. A plunger switch would have finished nicer but I had the magnetic switch and wanted to get it done.
Rockwood 8311ss
Pro Pride 3P hitch
Old 04-05-2015, 09:27 PM   #6
Did that 3 years ago and control the lights with a micro switch so when the door opens, the lights go on. Got the 12v from the refrigerator just to the side and bottom of the pantry.
http://www.forestriverforums.com/for...try-26573.html
Also added micro switches on both basement doors and the front storage area so the lights come on when the door(s) are opened.
ID:	73200   Click image for larger version
Old 04-05-2015, 09:31 PM   #7
That looks nice! The switch you used makes sense. Nice it doesn't need a big magnet for it to work.
Rockwood 8311ss
Pro Pride 3P hitch
Old 04-05-2015, 10:53 PM   #8
Nice clean install. I did one of those strips in my fridge, in lieu of the 10 watt incandescent. Its 3x brighter.
Back to you.....great addition.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-09-2015, 04:55 PM   #9
2gocamp's Avatar
Looks good. Can you tell me where you got the lights. Maybe a website link? There seems to be so many kinds available.
2gocamp is offline   Reply With Quote
Old 04-09-2015, 05:05 PM   #10
Flybob's Avatar
I found 12" strips at Walmart Auto section 2 for $18.00 in white, red or green
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-09-2015, 05:09 PM   #11
Pricey compared to a 5meter strip on ebay/Amazon.
Old 04-09-2015, 06:46 PM   #12
I will find the eBay seller and diode size and color and send your way when I find it. Mine were warm white around 3200k color temp.
Led chip was a 5630 (size) and of course 12vdc. So far the brightest 12v I could find. I paid around $10 for 16'.
Rockwood 8311ss
Pro Pride 3P hitch
Old 04-09-2015, 06:51 PM   #13
Seller on eBay was sgg-outlet. Click image for larger version
Name:	ImageUploadedByForest River Forums1428623479.218617.jpg
Rockwood 8311ss
Pro Pride 3P hitch
Old 04-11-2015, 08:57 PM   #14
2gocamp's Avatar
Thanks for the info. Much appreciated.
led, light
