Old 01-31-2015, 10:15 PM   #11
Swift2
Swift 2's Avatar
I changed my last TT out and found that the old filament bulbs had started to burn ( a dark brown area) in the ceiling above the bulbs. The new LED lamps are a lot cooler. I found that l I liked the warm white bulbs the best. The plain white bulbs tended to wash out the colors out.
It seems like every bulb I have taken out of my new 320RS seems to be the old incandescent type. I thought they they were supposed to be LED. Guess il start changing them out. I'm having trouble finding 194 warm white bulbs. Any suggestions?
Swift 2 is offline   Reply With Quote
Old 01-31-2015, 11:08 PM   #12
Mojojojo's Avatar
Amizon is my goto!
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-01-2015, 12:27 AM   #13
What LED bulbs are you buying?
leatherneck33 is online now   Reply With Quote
Old 02-01-2015, 02:20 AM   #14
jmcrae3891's Avatar
I got 2-20 packs of 921 LEDs from ebay. Just ordered some more for the turn signals and some more outside lights. I have a huge mountain trip planned in July with some smaller trips planned in between. Trying to get everything finished before July at least.
2003 Dodge Ram QC 2500 4x4
2003 Nissan Altima
2011 Forest River Lacrosse 301RLS
jmcrae3891 is offline   Reply With Quote
Old 02-01-2015, 11:42 PM   #15
When purchasing LEDs to replace incandescents you MUST look at the color temperature and Lumen ratings to find an LED light similar to the old lights. Color Should be "warm white" and/or 3000 Kelvins or less for a similar hue to old lights. Lumens (light output) should 200 lumens or greater. A lot of the cheap LEDs online are 5000-6000 Kelvins (much bluer and harsher) and 150-180 lumens (dimmer) than incandescents.
2011 8314 BSS Rockwood Signature Ultralite
2005 Dodge Ram 2500 Quad-cab SLT
Makoto is offline   Reply With Quote
Old 02-02-2015, 05:09 AM   #16
Has anyone swapped out the exterior scare lights? If so, which bulb did you use? Big difference?
I swapped out one of mine just to see what the difference would be and It is much dimmer than the old bulb.
Thanks,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 02-02-2015, 08:32 AM   #17
KyDan's Avatar
Post a link if you don't mind!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-02-2015, 09:55 AM   #18
RPAspey's Avatar
Thanks,
Don
Yup...used a Star-Lite 300 lumen 921 replacement. Works good. Changed the lens to clear instead of yellow. Nice and bright now.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 02-08-2015, 03:28 PM   #19
Thumbs up
Rigid Industries LEDs inside ... much less draw when dry camping and a lot less heat + more light (bright)
2002 Sandpiper Sport T28
1996 Dodge Cummins
Iceman_RNR is offline   Reply With Quote
Old 02-08-2015, 05:31 PM   #20
jmcrae3891's Avatar
They aren't as bright as I want. I cant recommend them as a replacement. I will probably go back to superbrightleds.com like I have before. Click image for larger version
Name:	ImageUploadedByForest River Forums1423438274.013312.jpg
2003 Nissan Altima
led
