Old 06-04-2011, 11:47 PM   #1
MOD Guy's Avatar
LED Taillight Upgrade
My Surveyor has taillights with the angled base. I have not been able to find a direct replacement for these type of lights. This kit is from Command Electronics, Part #K-0026
Kit has a set of LED arrays and lens covers.
Remove the old bulb and socket, connect the new LED base. The two existing screws are used to secure the LED array.
Much brighter than the old single bulb setup.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 06-05-2011, 10:51 AM   #2
Stevea1956's Avatar
Looks great! I've been wanting to change or upgrade the tail/brake lights on my Windjammer and these look they might be the solution.
Command Electronics state the upgrade is for the "81 style" tail light. I'm not sure how to determine what I have or if their upgrade will work. Is there a marking on the OEM housing?
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 06-05-2011, 10:58 AM   #3
sherdep's Avatar
Looks like an easy upgrade - thanks for sharing
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-05-2011, 11:49 AM   #4
MOD Guy's Avatar
I just went by how the tail light looks. These were a perfect match for mine. I don't think there is another style that looks "almost" like this. It is either this or it's something completly different looking.
High Springs, FL.
Old 06-05-2011, 09:18 PM   #5
49 year camping veteran
Maxterra's Avatar
Me likey!
Maxterra is offline   Reply With Quote
Old 06-06-2011, 10:23 PM   #6
cmcct's Avatar
Like it! I couldn't find anything like that at the time I did mine so I did this...
Gotta admit though, your way looks way easier.
ID:	6168   Click image for larger version
ID:	6169   Click image for larger version
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 06-08-2011, 06:50 AM   #7
To the best of my knowledge, there is no other light that "looks" the same as the Command light. But the Command name is on the lens, just above the step.
Also, the dimensions on this light are just a bit wider and shorter than the Bargman style 30-92-XXX light. If you replace one of those, you will need to do something about the lower two screw holes that will be exposed.
Kraig Whiting
Command Electronics
Kraig Whiting is offline   Reply With Quote
Old 06-08-2011, 11:20 AM   #8
Stevea1956's Avatar
I already ordered the upgrade kit K-0026. Can I return it if it won't work for my application?
Steve & Lauren
Old 06-08-2011, 11:29 AM   #9
Absolutely. Contact me if you have any questions. I can usually help out.
Kraig Whiting
Command Electronics
