Old 06-11-2012, 08:42 AM   #11
shawnj72's Avatar
Do they make 12 volt Outlets you can install for Accessories?
2006 Cherokee Lite 28A
2000 GMC Yukon XL
1 Wife 2 Sons 3 Daughters
2012 Days Camping 17 Practiced Camping in the yard 5/5/2012
shawnj72 is offline   Reply With Quote
Old 06-11-2012, 11:40 AM   #12
ken0042's Avatar
I installed one like this one, however mine has 2 USB outlets in addition to the 2 cigarette plugs.
We do a fair amount of dry camping, but even when we have power available it's nice to be able to plug in 12 volt accessories.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 06-11-2012, 11:52 AM   #13
Another rat in the race
jar3316's Avatar
I used these installed them through out the trailer. The control boxes usually have a few extra slots to use.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 06-13-2012, 10:31 PM   #14
cmcct's Avatar
Yes, did that too. Just last weekend, found a 15" RCA LED, LCD TV with HD etc,etc, to replace the 15" LCD that I had in the trailer. Why you may ask, well, we only dry camp and the new RCA requires only 2 amps of power versus the 4 amps of the old unit, plus it has a much better quality picture. On a side note, I did see the RCA in 19" and 22" with built in DVD players and 12 volt input (still) with 4 amp power requirement. Since having the trailer, I always keep an eye open for TV's with a 12 volt input (drives my wife crazy), and I have to say RCA has the largest selection I have seen so far. By the way, the new TV was $99.00 at London Drugs here in Vancouver.
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 06-14-2012, 10:24 AM   #15
jar3316's Avatar
Quite a few Flat panel TV's use dc power. look at the power set up if the TV uses a separate power box then you can bypass that and go straight to DC from your RV (USING THE PROPER VOLTAGE).
Vizio (spelling?) is on of them ( I have a 22") that uses an external power transformer and converts 110AC to 12VDC so you just take the transformer out and go to radio shack and get a 12V cig. jack that can handle the Amps with the right tip.
Old 06-15-2012, 02:36 AM   #16
Namchief's Avatar
Originally Posted by Swinks View Post
Im also going to put a wall mounted T.V. in our 5th wheel. I'm just a little nervious about the strenght of the wall studs. I believe there generally 2X2 studs. It would be a small T.V maybe 20"-30". Are people having good luck with wall mounted T.V.'s in there trailers?
I have a 27HFS TT not a 5th wheel. I mounted a 32" LED in the main area. I also left on the main base when measuring the height of the mount . I did this so I would not have to remove the tv while trailering.3k miles and still hanging straight. I do use 2 pillows to protect it in between the TV and the slideout.
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
Old 06-20-2012, 09:05 AM   #17
another 27HFS TT
I've got a 27HFS TT also - would love to see a photo of your installation.
Kathy
waterlover63 is offline   Reply With Quote
Old 06-20-2012, 10:01 PM   #18
Namchief's Avatar
Will do within the next few days
1999 Yamaha Grizzly
