Originally Posted by R Whitlow
You need a larger wattage power supply to push watts required. If it is a very long distance the wire within the led strip will have a voltage drop. The specs will address the max length that can be cinnected. To overcome this you can run a wire along the strip to catch the second string of led lights.
Sent from my SCH-I545 using Forest River Forums mobile app
Actually u can buy boosters to put every 32ft....or wire like you said. ..
My simple solution was to put a y connector right at the controller box...ran 2 strips to the right and 2 to the left...worked out perfect as I negated any voltage drop past 32 ft....stock controller and 4amp pwr supply light em up bright and consistent. ....
Been behind the crown moulding 2 yrs now on 24hrs a day and stil purring along
sent from fat fingers via a space dish thing with no regard to grammer.
