Old 02-17-2013, 10:32 AM   #1
Azabva's Avatar
Send a message via Yahoo to Azabva
Led's
I'm wanting to change the rear taillight, turn signal and brake light from standard bulb unit to LED units. Any ideas on the comparable manufacturer and size?
I have a 2013 Sanibel 3500.
Azabva is offline   Reply With Quote
Old 02-17-2013, 10:55 AM   #2
TURBS's Avatar
There was just a post the other day .
You should check it out.
Search "can you see the difference"
That should get you close
Old 02-17-2013, 02:47 PM   #3
LKicklight's Avatar
Led's bulbs
superbrightleds.com
this is the site where I get most of what I use..prices are very well also...you can match your existing bulbs to what they have..
LKicklight is offline   Reply With Quote
Old 02-24-2013, 01:02 PM   #4
LEDTrailerLights.com - LED Stop Turn Tail (STT) lights for horse, cargo, utility trailers, RV and 4x4 applications has some 1157 LED tail lights
BobandArlene is offline   Reply With Quote
Old 02-24-2013, 02:03 PM   #5
LKicklight's Avatar
Led's bulbs
Superbrightleds.com
use this site, ask for auto bulbs..match your current bulb numbers with that of the led's..check out the brightnest for each bulb shown..the brighter the bulb the pricey it becomes....any problems just send me a private message i have been buying from this company for years, good warranty...
Lkicklight
Old 02-24-2013, 02:49 PM   #6
On my previous cargo trailer, this is the LED bulb I used - 1157 LED style:
LEDTrailerLights.com - 1157 and 1156 LED replacement bulb style
Old 02-24-2013, 03:09 PM   #7
LKicklight's Avatar
Bulbs
Those are pretty standard bulb numbers..one had a single filiment the other had two (ie; brake and turn signal) just get the corresponding bulbs in LED's to matcch those numbers..what is really a kool bulb is one for the front turn signals..normally the turn signal bulb is amber...get what it called a switch back bulb..when it blinks it goes from amber to white..constantly...have these on the vette and on the 2500DH...
Old 02-24-2013, 04:54 PM   #8
LKicklight's Avatar
Led brake/turn
Just purchased these on ebay for 10.99 for the pair..they are red to match the lense cover..make sure you do that..
Put in 1157 led bulbs..there are more offered there..
