Old 04-21-2014, 10:30 PM   #21
mark0224's Avatar
Use to crank all jacks with an 18 v drill but with the heavier trailer it wouldn't cut it to jack it up to get the trailer off the hitch. Upgraded to a corded 1/2 inch low speed high torque drill. This beast will make the tongue jack work with this mod. And will be even better when I hook up an inverter off the battery to run it.
ID:	50674   Click image for larger version
mark0224 is offline   Reply With Quote
Old 04-21-2014, 10:49 PM   #22
mark0224's Avatar
By the way not raising off ground, just touch down for the stabilizers. The hitch jack on my old trailer worked with the 18 v drill, but this trailer is 2000 lbs heavier and it just wouldn't cut it so I tried a 20 v and it wasn't enough, impact gun was too much broke roll pin in the jack.
Old 04-22-2014, 02:21 PM   #23
mark0224's Avatar
Kept looking at our slide and it appeared to have a slight sag in the middle so decided to give it a little boost in the middle using one of those slide locks for a post. Slide looked a lot better and when I tried to put in seemed to work smoother. Well went out to the shop today and started turning a post to go in permanently. Will post pic when I finish.
Old 04-28-2014, 05:26 AM   #24
BiigDaddy's Avatar
Originally Posted by mark0224 View Post
Blue Led lights around inside of Slide, my wife liked this one.
Ooooooh. I liked this one! Nice!!
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 04-28-2014, 09:03 AM   #25
mark0224's Avatar
Just make sure when you do it if slide gets hold of it putting it in or out will suck it into slide or rip off wall. Fasten it so it doesn't touch inside seal when slide is out. Also make sure there are no sags in lights so when you put them out doesn't get drawn out with the roof of slide.
Old 04-28-2014, 09:07 AM   #26
mark0224's Avatar
My favorite is the Front jack makes my life so much easier but like this one for looks, going to be doing similar under the awning with the blue lights. Saw them at a local Rv show and they must be the new thing this year .
Old 04-28-2014, 06:18 PM   #27
mark0224's Avatar
Added some more to ours.Also 303 protect on all decals.
ID:	51179   Click image for larger version
ID:	51180   Click image for larger version
Old 04-28-2014, 06:20 PM   #28
mark0224's Avatar
Awning can now be tilted and has a cradle in the middle for when its in.
Old 04-30-2014, 10:18 PM   #29
mark0224's Avatar
Got my awning lights today going to try to install them next time the rain stops, blue leds under the inside edge of the awning and underside of the trailer same side, should light things up good.
Old 05-07-2014, 05:03 PM   #30
mark0224's Avatar
Just took these pics can't wait till night so I can really see what they look like. Saw blue LED's on trailers at RV show and wanted them under my awnings.
ID:	51935   Click image for larger version
Think about things before you do them make life easier not harder.
led, plumbing, modifications
