Old 12-15-2013, 03:37 PM   #91
10x
Originally Posted by BigBaron View Post
You have to check them lumens of the bulbs you are buying. A standard wedge base bulb is around 288 lumens. I have found that it takes eighteen 5050 LEDs to equal that lumen output.
So how are these?
20 T10 194 921 168 W5W 24 1210 SMD LED Warm White RV Landscaping Light Lamp Bulb | eBay
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 12-15-2013, 04:52 PM   #92
rbneron's Avatar
They're only 100 lumens each; approximately 1/3 the light output of your incandescent bulbs.
rbneron is offline   Reply With Quote
Old 12-15-2013, 11:32 PM   #93
At first I ordered 24 led white light wedge based little discs but they were not bright enough and my wife didn't like the cold white light. I got 10 for about $20 from China on eBay. I then ordered 48 led flat panels in warm white. They are about 2x3" with a little pigtail wire leading to a wedge base connector and have a peel off sticky back. They work great. Bright enough and the warm white light is close to the incandescent bulbs. I got 9 of these from China on eBay for about $30. I also ordered 2 60 led bulbs with a bayonet base for $9 from a US firm ( Chinese importer) on eBay for the porch and tongue lights. All work great so far. Only cost about $40 if you don't count the 10 little bulbs that I didn't use.
markly86 is offline   Reply With Quote
Old 12-16-2013, 08:27 PM   #94
Thanks for the SMD equivalent, good to know. I have recently seen 15 rectangular smd's on circular disc format, but not sure if they emit greater lumens than the 5050's one for one. As far as I could tell there doesn't seem to be a definitive comparison, that I could find, to determine lumen comparisons between halo, and LED type bulbs.
2012WhiteSolera is offline   Reply With Quote
Old 12-16-2013, 08:31 PM   #95
10x, I have found the 5050's, bulb to bulb with the same flat disc size, are brighter than those you sent the link to.
Old 12-30-2013, 09:10 AM   #96
ProjectPro's Avatar
I bought 23 921 replacements (Warm White 13 LED T10 socket T10-13WW SKU323 (15751W-02)) from LEDforRV.com. I bought three at first to try them, then ordered the rest because I was so impressed. DW hates the bluish cold LEDs, but these are very close to the look of the incandescent bulbs they replace. I like not hearing the converter fan run and the reduction in heat, but for me the big payoff was getting rid of a fire hazard. All of the lights I removed had brownish-black areas on the fixtures around them from the heat. That doesn't look safe to me, and the no-name cheapo fixtures FR used weren't comforting either.
ProjectPro is offline   Reply With Quote
Old 01-02-2014, 05:25 PM   #97
Already ordered my LEDs for inside. My next project will be to add LEDs just above the clearance lights in the back. There going to be red and work with the brake/turn signals so cars that are behind the car behind me will know what I'm doing.
RedDragon is offline   Reply With Quote
Old 01-04-2014, 06:12 AM   #98
BKennedy's Avatar
Lightbulb LED Replacements for overhead lights
I had replaced all of my standard bulbs with WLED-xHP10-DAC from SuperBright LEDs.com They have a special on this bulb now, I originally paid $14.95ea. they are now $9.95 Very good deal and these are very bright.
FYI.
Happy Winter Camping
BK
2011 Flagstaff V-Lite 30WFKSS
2014 F-350 Super Duty Lariat 6.2
BKennedy is offline   Reply With Quote
Old 01-06-2014, 08:53 PM   #99
Not bad. I paid $89 for 26 led bulbs.
