Old 03-22-2008, 09:23 PM   #11
moorer2's Avatar
Lynx levelers. I like them because they are very light weight and a breeze to use. I rarely have to do a great deal of leveling. Most of the spots we camp at are pretty level to start.
moorer2 is offline   Reply With Quote
Old 03-22-2008, 09:41 PM   #12
welshman599's Avatar
Send a message via MSN to welshman599
Side to side first since you have to use the tow vehicle to back/drive onto the low side block/plank/ramp. Then use your jack to give you level back to front. your stabilizing jacks lose their stability if extended too far so blocks are a good thing there, and some folks use those nylon cutting boards (from Dollar stores) under their jacks to keep them from digging in. They wash off well and store very nice too. I don't know if long planks to catch both tandem wheels is necessary for weekend camping.... two short blocks do the same and are easier to stow. For longer term camping or seasonal though, I place boards/planks under both sides with thicker for the low side.
Remember that if you have a slide out (full double anyway) you need your slide-side about an inch high when you set up... it will level out when the slide is extended.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 04-13-2008, 10:22 PM   #13
gillguy's Avatar
Lynx Leveler blocks. They are light weight, easy to store and clean. I have one pack of ten, but plan on getting another set. we like the mountains and some places aren't real level, but not that bad, two packs would be nice though. They work real well.
I level side to side first when I have to, then put the stab jacks down. I have large sand pads on them and only put Lynx block or wood under them when I have to. That's another reason I would like another set of the Lynx blocks, some times I don't need many for side to side, but some times the stab jacks aren't long enough. Like I said though, we enjoy the mountains. At the beach we usually don't need the Lynx blocks.
Good luck
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
gillguy is offline   Reply With Quote
Old 04-14-2008, 08:25 AM   #14
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Originally Posted by symbasden View Post
I use air bags that I made based on the level-airs since they are out of production...
Interesting. How, and out of what? Some details please.
dimurrrw is offline   Reply With Quote
Old 04-14-2008, 05:27 PM   #15
wildwood's Avatar
First----Level side to side by adding long 1 x 8 x 60 that fit below both tires on the low side.
Second--- level front to back by tongue jack and then drop four corner stabilizers for support.
I use 1 x 8 x 60 in long for wheels for side to side levelling
2 x 8 x 12 in long qty 4 for stabilizers. We tried some of the plastic blocks but they give/depress too much, the wood was more stable.
we add a rectangular slip on support to the bottom of our tongue jack and support on a couple 2 x 8s
2008 Wildwood LE 29BHBS
wildwood is offline   Reply With Quote
Old 04-14-2008, 06:22 PM   #16
For 9-years I used home-made wooden pieces of different thicknesses to which I would build platforms of required height to pull the trailer wheels onto. I had plastic levels attached to the front and side of the trailer which yellowed over time.
With the purchase of my new travel trailer I purchased a new leveling system to which both the wife and I find a lot better. I use a Hoppy Hitch Level which permanently mounts to trailer tongue for both side-to-side and front-to-back leveling. Comes with a cover as well. I back in or pull into the RV spot. The wife takes a look at the level and turns the dial until it becomes level and a pointer indicates number of inches required for adjustment on the appropriate side. We than add the required number of leveling blocks from the convenient storage bag. We purchased our leveling blocks at Wal-Mart which we found to be the least expensive at that time. Could possibly be the Lynx brand but I can not remember. (I have two bags of these and use some under my tongue jack and under my stabilizer jacks when required)
OREGONCAMPER
2008 Rockwood 8317SS - 2010 F150
2013 Camping Days: 22
2012 89 2011 50 2010 61
OregonCamper's Pics click here
OregonCamper is offline   Reply With Quote
Old 04-14-2008, 08:20 PM   #17
Grape Escape
May I ask where you puchased Happy Hitch level and approx cost?
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 04-14-2008, 09:35 PM   #18
Originally Posted by dezolen View Post
May I ask where you purchased Happy Hitch level and approx cost?
I purchased mine at the RV dealer where I purchased my RV. Nolan's RV & marine in Denver, CO. I purchased one for a friend at a local RV supply store. Both costing around $10.00
OREGONCAMPER
Old 04-16-2008, 09:37 AM   #19
hunt4240dw's Avatar
Send a message via MSN to hunt4240dw
Lynx Level blocks ... Light weight yet strong.
David
The Hunts
2012 F150 Ecoboost, 3.55, tow package
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
hunt4240dw is offline   Reply With Quote
Old 02-12-2009, 11:56 PM   #20
All you guys just keep talking and stressing out about the same thing. Camping World has this handy electronic gadget that has lights that flash to aid you get your RV leveled. Mind you, I have a 35' class A, but that doesn't matter. Check it out and quite stressing out.
dmzkiller is offline   Reply With Quote
