Old 02-19-2008, 03:22 PM   #1
Leveling
What Do Most People Use To Level Their Tt.
2x6 Boards,plywood,stackable Blocks?
Also Is It Common Practice To Block Wood Under
Stabilizer Jacks?
HOWIE BEDELL is offline   Reply With Quote
Old 02-19-2008, 03:46 PM   #2
I use as little as possible. Usually only up to 1/2 inch plywood under a 2x6 cut to about 12" in length. Only the amount needed to fit between the dual wheels, i.e., place one in front of each wheel to either back up or pull on. Anymore than that I look for a flatter spot.
I use about a 12x12 under the stabilizers if on soft surfaces. Hard surfaces don't need anything.
Paul B
2001 Excursion PSD
2000 CRV Honda
2006 829GRSS Flagstaff TT
2004 Twin 2000i Hondas'
Paul B is offline   Reply With Quote
Old 02-19-2008, 04:17 PM   #3
Oakman's Avatar
I have 1x12's and 2x12's cut into cut into 12 inch lengths that I use for leveling. I always put wood blocks under the rear stabilizers so that I don't have to lower them as much.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-19-2008, 05:10 PM   #4
wildwood's Avatar
I use 1 x 8 x 60 in long for wheels for side to side levelling
1 x 8 x 12 in long qty 4 for stabilizers
wildwood is offline   Reply With Quote
Old 02-19-2008, 06:21 PM   #5
budfans's Avatar
I Have 2x6 And The Stackable Blocks And I Set Up A Cordless Drill With A Socket To Run Down The Stabilizers And Put The 2x6s Under Them
07 285B+ cherokee 5er
02 F350 power stroke c/c
budfans is offline   Reply With Quote
Old 02-19-2008, 07:03 PM   #6
I use air bags that I made based on the level-airs since they are out of production...
Before that I used home made wood blocks that interlock like lynx do.
symbasden is offline   Reply With Quote
Old 02-19-2008, 07:04 PM   #7
powerboatr's Avatar
i use the big yellow lego blocks( 1"x12"x12")
two under the front jack pads always
a set long enough to roll up on to keep the rubber off the concrete or gravel or soft sand if we are staying a while.
if we are staying just one or two nights then i forego the wheels and just use em if we are way off level
for the rear stabilizers i use about 5 each side so i dont have em extended in a long skinny configuration
plus we have a bunch of 4x6 blocks about 10" long to build up under the rear stabs if we are in a weird place, and assorted 2" x 6" pieces for that really weird site
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 02-19-2008, 10:23 PM   #8
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I've always used wood under the stab jacks. For leveling, I cut 2x6" leveling boards in a step-like formation. I stacked up what I needed and backed onto them.
Now, my trailer sits on cement blocks.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 02-22-2008, 09:14 AM   #9
TWhaylen's Avatar
Good information here as I as well am trying to determine the best way to level the TT and what to use
2005 Surveyor SV234
2004 F-150 Supercrew Lariat / 5.4L / 3.73 Gears
Reese Friction Sway
Voyager Brake Controller
WD Setup
TWhaylen is offline   Reply With Quote
Old 03-14-2008, 10:10 AM   #10
personal experience, but I have a assortment of wood from 2x4x??, 2x10x??, chunk of railroad tie, 6x6x8, yellow leveling blocks, and wheel chocks. I live in WV so u have to be prepared, not much flat land. I have found the best way to level is side to side first and then front to back. I do put wood under the stabalizers because mine have such a small footprint, usually a 2x12x??.
DW of 12 yrs 6yr old girl, Twin 9yr old girls, 9yr Old boy (10 months between the Three)
2010 Suburban 1500
2006 Sea Ray 185 sport
On the hunt for a new travel trailer
wvsteve is offline   Reply With Quote
