Old 07-02-2013, 06:35 AM   #1
tom50mg's Avatar
Licence Plate Bracket !
Returned yesterday from a weekend campout and while walking around the trailer this morning I saw the licence plate lying on the ground,the plastic brackets had broken off that attach the plate!Anyone know of a modification for this problem.
tom50mg is offline   Reply With Quote
Old 07-02-2013, 07:09 AM   #2
GalsofEscape's Avatar
I had that happen this past fall. Found the license plate in the yard.
The RV dealer had a metal license plate bracket that we used to attach the plate to the rear bumper. I did not want to have the stupid plastic tabs that would just break again.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 07-02-2013, 07:13 AM   #3
tom50mg's Avatar
There is an idea,I am lucky it fell off in my driveway,will look into that thank,s!
Old 07-02-2013, 07:42 AM   #4
Road-King's Avatar
I had the same problem. I took a pair of tin snips to an old licence plate I had laying around and made a new metal one for mine.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 07-03-2013, 06:25 AM   #5
tom50mg's Avatar
Problem solved,I cut the remaining tabs off of the tail light housing and installed the plate on the rear of the trailer with coated screws!looks fine from the drivers seat..lol
Old 07-03-2013, 06:31 AM   #6
Make sure you caulk the screws to prevent water intrusion. I would change the coated screws with stainless steel ones.
Old 07-03-2013, 01:00 PM   #7
Dodge Guy's Avatar
I ripped mine off when I took the cover off this spring. I just used some of the metal brackets with the holes in them. I cut them long enough so the plate sits in the same spot. I took lens off the brake light on that side and screwed the brackets into the housing and then notched the lens to clear. you can`t even tell it ever came off and is much stronger than before!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
