Old 01-05-2014, 07:16 AM   #1
Lighted Switches Removal??
We just got a new Vengeance 29V. We love it except for 1 thing. ALL the light switches are illuminated in this blue retinal burning while you sleep mode. The one in the bed area is an easy fix, we just hang a jacket over it on a handy command hook. To the right of the bed on an overhead cabinet is a main switch bay with 6 of the little eye burners and it shines right in over the bed. Has anyone done a crafty little cover for them? I am thinking the easiest fix would be 2 hooks and a little fabric cover but wanted to see what sort of awesome ideas you folks have.
melissa16 is offline   Reply With Quote
Old 01-05-2014, 07:25 AM   #2
The (Water pump,water heater on Gas) are illuminated during use,they can be turned off a nite. What other (Blue lights are on all the time? Youroo!!
Old 01-05-2014, 08:09 AM   #3
Every single switch in the camper is illuminated ALL the time. all the lights have wall switches and those are the illuminated ones . It is supposed to make it easier to find the switches in the dark but they are brighter than a kids night light
Old 01-05-2014, 08:27 AM   #4
A black Marks A Lot or paint will remedy the problem or take the switch out and clip the wire to the bulb.
Old 01-05-2014, 08:31 AM   #5
abjb's Avatar
You should be able to get un-lighted switches just like your lighted ones.
I found switches just like ours at Ace Hardware.
Or like Old Coot said
Pull one out and you might be able to cut the LED, just cut one wire.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is online now   Reply With Quote
Old 02-19-2014, 10:03 PM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
scissors and black electrical tape works...
donanddona is offline   Reply With Quote
Old 06-01-2014, 07:35 PM   #7
Edgycanuck's Avatar
I too was tired of the annoying blue light while trying to sleep...... So I did something about it! I'm a journeyman electrician so knowing what I was looking for certainly made it easier to do this mod.
If you remove the four screws holding the panel in place it will fall into your hands with a mess of wire, on the back of the switches you'll see a white (in my case) wire jumpering between all the lit switches a well as the tank level gauge and then ending in a splice that has a number of wires spliced together. If you pull off the white wire stake-ons on the switches that will remove the chassis ground point on the switch preventing it from lighting and a nice nights sleep. You can either leave the stake-on and splice together (maybe wrap some electrical tape on it, or do like I did and cut them off and splice them using either a B-2000 (what you can see in my pics) or a #29 marrette. I only disconnected the water pump and got water tank switches as we usually leave them on but kept the outside light and tank heaters connected so we don't forget to turn them off. Click image for larger version
Name:	ImageUploadedByForest River Forums1401669130.941313.jpg
ID:	54080Click image for larger version
Name:	ImageUploadedByForest River Forums1401669155.217742.jpg
ID:	54081Click image for larger version
Name:	ImageUploadedByForest River Forums1401669182.266146.jpg
ID:	54082Click image for larger version
Name:	ImageUploadedByForest River Forums1401669209.171960.jpg
ID:	54083Click image for larger version
Name:	ImageUploadedByForest River Forums1401669229.291767.jpg
Edgycanuck is offline   Reply With Quote
