Old 02-21-2013, 12:31 PM   #11
2005 Fleetwood Pride 38RL
I finally made it back onto the roof and after what is approaching a year, I found my reflectix in exactly the same shape as when I installed it. WoW, I am impressed! No degradation at all, maybe a slight, but very slight discoloration.
I wish I could attach these photos to the first post in this series but I do not know how to do it.
As you can see from the pictures, it is a very simple process to install the reflectix.
Please note the color of the reflectix on the a/c cover then the reflectix on the outside water filter. I added the reflectix cover to the water filter today and you can see the color difference between a year ago and today.
My wife cut reflectix to cover all of our windows and used small (tiny) pieces of sticky velcro to attach to the window screen frames. She used larger peices in the beginning but it just ripped the reflectix when removing so she used 1/4 inch pieces and just let the velcro edges overlap about 1/8in. using 6 pieces it works just great. easy on and easy off. We also used the velcro/reflectix inside each of the inside of the roof vent openings along with the interior lining of the exterior the roof vent covers.
We are enjoying significant cost reductions in both electric and propane gas for the heater.
Enjoy!
I also used the reflectix around my outside clear case water filter to prevent algae and freezing.
BBDAWG is offline   Reply With Quote
Old 02-21-2013, 07:55 PM   #12
10x
That is not reflecting the sun away due to it mounted on the inside of the cover. It probably is holding heat, you need to get heat away from the condensor. I would remove it.
10x is offline   Reply With Quote
Old 02-21-2013, 09:00 PM   #13
I did a test a few years ago in july in Mytle Beach at Pirateland and they are posted here on the forum, here is what I did to reduce the heat load in my camper now the temps in Mytle where around 90 to 97 degrees.
To start with we had a 2006 8314ss ForestRiver Rockwood, it came with a 13,500 BTU Dometic A/C unit. The first time we were at Mytle Beach this unit would not cool an out-house, it was a terrible two weeks acept at night when the heat load is reduced. The second time we when this is what I did:
1. My wife made instulated curtains and installed them with spring rods on all of the windows aand we kept them close during the day.
2. I added reflictix to the bathroom skylight, both windows in the doors and to the two vents in the roof.
3. I replace the 13,500 BTU Dometic A/C unit with a 15,000 BTU Carrier unit.
4. I set the T stat to 72 degrees and set the fan control from "AUTO" to "ON", by doing this it help keep the air moving all of the time which help to eliminate hot spots in the camper.
5. The day/night shades, I found by closing the night shades it generated more heat at the windows so I left the night side shades up but keep the day shades closed, I used a temp gun and this is display on the post. Remember night shades are dark and they attract heat.
Now after doing all of this the second time around the A/C system did cycle you could hear the compressor come on and shut down but the fan kept runing, i must say this did work well for me.
Now to be up front with you, I would not line the inside of my a/c cover and here is why:
1. By adding reflectix inside of the cover it refects heat but it is making the componets hotter the reflectix act as an insulator the cover is white in color and that is so it does not attract heat and the material that the cover is made of is thin, the A/C system is design to operate as it is. I would not be concern for the compressor, my concerns would be over heating the electrical. The vents on the cover are design to allow a certain amount of heat that the componets are producing to vent safely and by holding more heat could cause a heat overload.
If you can get the heat loads under control with in the camper then the A/C system will operate better, this applies to your home as well. I like your idea but this could case the system to fail sooner then exspected
Remember this, if everthing in the camper is hot the a/c system has to cool all surfaces as well, the a/c system has to remove all heat and over come the heat loads...people included, the average person just setting in a chair or standing produces appox 300 to 350 BTU's an hour.
If you are interested in the test I did on my camper let me know and i will try to find it here on the forum.
Old 02-21-2013, 09:04 PM   #14
I agree, mold and alge like wet ,dark and warm areas to grow, i would remove it. If you are concern I woud get a UV system.
Old 02-22-2013, 05:03 AM   #15
Toy-aholic
I would think a solar powered fan mounted to the cover would do a better job off heat removal.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
cooling, reflectix, air conditioner
