Old 04-04-2011, 06:35 AM   #1
looking at LED tail lights. how do it know what series lights i have (#84/86???)
i am looking to put some LED tails lights on my rig. these appear to be a simple solution LED Tail Light Upgrade Kits for Bargman 84/86 Series - Manufactured by BARGMAN . however, i am not sure how to tell what "series" lights i have right now. does anyone know how to figure this out? i cannot find any markings on my current, OEM lights.
2006 Cherokee Wolfpack 295WP - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Starlight Revolution 300 lumen LEDs EVERYWHERE!
2012 Dodge 2500 - deleted and tuned by H&S performance
Bocephus is offline   Reply With Quote
Old 04-04-2011, 07:40 AM   #2
Wanna Be Camper
SaskCampers's Avatar
Did you pull one of the bulbs out and look at it? If it is a dual filament bayonett bulb it could be an 1157.
Here is a link to help you identify the bulbs.
http://autolumination.com/
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-04-2011, 06:30 PM   #3
how does the bulb number tell me what style of light assembly i have?
Old 04-04-2011, 07:05 PM   #4
caper's Avatar
Why don't you just order the replacement LED bulb? This is an easy fix.
1157 or 1156 bulb replacement LED*
Perfect low cost LED upgrade for Stop, Turn, Tail light applications, or park/turn applications.
*Notes for motor vehicle applications:
If LEDs of this style are being used behind a colored lens, the LED color must match the lens color.
ANY color LED can be used behind a clear lense, but if a colored lens is on your lights, the LED color needs to match the lens color.
Don't use a WHITE LED behind a colored lens because the white LEDs will not show up sufficiently through the colored lens.
1157 model
Two Function: For Stop/Turn, Tail light applications, double contact base.
See hints and tips for info on vehicle flashers and LED lights
Two contact base
RED
p/n:1157-R
$12.95
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-04-2011, 07:08 PM   #5
Herk7769's Avatar
I looked at the LEDs you linked to. They are BULB replacements.
You need to identify the base of your BULB to determine what base you need to order with your red LED board.
Having struggled with mounting LED boards in the existing fixtures I can tell you that you will be wasting your money with this mod. However if you insist on trying here is how I mounted my LED boards in my interior light fixtures.
I used extreme duty velcro pile on the fixture and zip tied the extreme duty hook side to the LED pad.
HAM CALLSIGN - KC3FFW
Old 04-04-2011, 07:24 PM   #6
i like the look of the big LED light assemblies with multiple little leds....not just a bulb. i might just get the complete assembly and take the old ones off.... and then of course get led clearance lights for the top, rear as well. it just wouldnt match with leds on the bottom but none on the top
Old 04-04-2011, 07:29 PM   #7
Herk7769's Avatar
Then you will need to buy a complete assembly. The ones you linked to will be invisible behind your existing red lens.
Remember you MUST buy the correct color LEDs for the color lens you are replacing. Clearance lights require YELLOW LEDs.
If you want to SEE the individual LEDs you will most likely need to buy a specific assembly that is designed to do that.
Old 04-04-2011, 09:38 PM   #8
cmcct's Avatar
Here is what I did...
Changed the tail lights to Grote LED units. Also did all the marker lights (Grote) as well. License plate light is a Truck Lite unit. It's amber because I could not get the clear version of that light at that time as they had only just been released into the market and I couldn't wait for one. What is really nice is that I have found the LED lights to be FAR more visible in the rain and at night.
ID:	5184   Click image for larger version
ID:	5185   Click image for larger version
ID:	5186   Click image for larger version
ID:	5187   Click image for larger version
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 04-04-2011, 10:22 PM   #9
i tossed around the idea of doing something similar to what you did. even though it means using a completely different light assembly, i think i would still like it better than the OEM housings. either way i do it, i want to use a clear lens lamp assembly like i have on my atv. it is clear/chrome looking with bright red LEDs.
Old 04-05-2011, 07:33 AM   #10
Herk7769's Avatar
I would check with DMV North Dakota before I spent a dime.
If you buy the DoT approved ones you know you are safe from tickets and such.
