Old 07-10-2016, 08:21 PM   #1
Kenny kustom's Avatar
Low voltage
At the site today, the ems kept kicking out due to low voltage.
How often have you seen this?
Doubtful we will be back at this spot again, but curious if this is a common occurrence?
Time to add a Hughes to the basement?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Kenny kustom is online now   Reply With Quote
Old 07-11-2016, 05:45 AM   #2
Canadian Member
itat's Avatar
I've had my PI EMS for 3-4 yrs. and it's shut down power 2-3 times. Always due to low voltage. Once was for our entire stay at a local Provincial Park earlier this year. In hindsight, I probably should have spent a little extra and bought the Hughes Autoformer instead of the EMS.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 07-11-2016, 06:14 AM   #3
TURBS's Avatar
Once last year in Nashville Tennessee.
Hot, humid and a full park.
First time in 6 years .
I think this is more common on 30 amp campers?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-11-2016, 06:38 AM   #4
jeff
jeff64's Avatar
Had it happen 1X this year so far and it was hot and rainy. Shut down like 7X that day, came back up 3 min later. Guess it works as advertised
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-11-2016, 08:43 AM   #5
Would you recommend initially getting a Hughes Autoformer to stop the problem before it starts?
Thanks!
RV_Fan44 is offline   Reply With Quote
Old 07-11-2016, 09:04 AM   #6
Thanks!
The only way to stop it, is either kick out half the campers or upgrade the CG electrical system.
2016 Sabre 36QBOK
Old 07-11-2016, 09:26 AM   #7
An Autoformer does not take the place of PI EMS other than it does provide some surge protection. Even if the power condition light does not illuminate on the Autoformer, its not going to tell you why like the PI EMS will. And the Autoformer will do nothing for high voltage.
High voltage is just as common as low voltage in older campgrounds which were wired before most RV's had AC, Microwaves etc. Depending on how they are wired, and where your site is located on the circuit, someone pulling a load further down the circuit can cause a high voltage condition on your site even though your site was showing low voltage before they applied the load. Be especially on alert at places where 2 sites share a common pedestal.
Mr Havercamp is offline   Reply With Quote
Old 07-11-2016, 10:56 AM   #8
Battled this all week. We had 50 amp service. Power averaged about 108V the lowest was 98V. Pedestal was equipped with 50,30 and even 20 all had same voltages. I had to bypass EMS just to get some power. CG was not concerned in the least. They said no one else as ever made a complaint and my equipment might be faulty, of course I showed them the EMS and volt meter readings which were exactly the same. Then they preceded to tell me I was tampering the park equipment by testing their receptacles with my volt meter and could evict us. Prince Gallitzin State Park PA btw.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 10 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 07-11-2016, 11:56 AM   #9
TURBS's Avatar
Customer is never right
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 11:57 AM   #10
Canadian Member
itat's Avatar
Thanks. Do you have both?
I've never seen the voltage be too high, just too low and a hot skin condition at another camper's site.
voltage
