Old 06-16-2013, 03:57 PM   #101
wmtire's Avatar
Took a trip to Hot Springs Arkansas earlier this week and the camera(s) did great. I ended up mounting one in the back window of the trailer, and it helped me a lot in seeing who was behind me and where.
I had previously added a 12 volt outlet to my trailer, that is controlled by my aisle light switch on the control panel. I leave the camera turned on at the camera itself, then just use the control panel switch to turn the camera on/off when traveling...thus don't need to raise my blinds or climb over the recliners to mess with the camera. Just reach inside the trailers door to turn the camera on/off. I also now have the camera powered by the trailer battery, and thus don't need AA batteries or a 120 volt connection.
Here is the forum where I added the outlet:
Adding a 12 volt outlet for the wireless camera
I went to Radio Shack and bought their 6 foot long Enercell cord #273-348 and then picked out the corresponding plug which is a type H, to fit the GE camera. Radio Shack gives one plug per cord, so it cost $12 for the cord and plug.
Note: when you look this model number up online it states it is a six inch cord, but it's six foot.
I then did as BarryD0706 has stated previously and found a 5 volt cell phone car charger I had from past phones (since most cellphones use 5 volts like the camera does) and cut the phone end off it. I also cut one end off the Radio Shack cord, then spliced the Radio Shack Cord to the car charger cord..........making sure I had the polarity correct.... which is positive on the tip end of the car charger and positive on the inside of the Type H end.
I mounted the camera to the back window by using a T-bracket screwed into the window frame, then covered this bracket with stick-on velcro, and placed the other velcro side on the camera base.
Here are some pics showing the mounting, and cord splices.
Make sure you do not use anything that supplies a full 12 volts to the camera, as it needs 5 volts.
Name:	12volt outlet1 002 (Large).jpg
ID:	33361   Click image for larger version
Name:	12volt outlet1 003 (Large).jpg
ID:	33362   Click image for larger version
Name:	12volt outlet1 001 (Large).jpg
ID:	33363   Click image for larger version
Name:	12volt outlet1 005 (Large).jpg
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-07-2013, 08:48 PM   #102
PHS79's Avatar
I remember reading this thread when it first started and then just ran across it again today when doing a search.
I think I may buy one of these since it could actually be dual purpose for us. I could use it as a back up camera and I could also mount a camera in the camper so my wife feels more comfortable leaving the camper when our DD goes to bed since she would be able to "keep an eye on her" with the night vision feature.
Has anyone done a mount for using it as a backup camera that doesn't involve using a magnet to attach it to the truck? I saw that the camera has a couple of pivot points, but does it have a swivel so it can look to the side of the cameras base or can it only be aimed in the straight plain from the base?
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 07-07-2013, 08:57 PM   #103
Will rotate 180 degrees horizontally also.
Plexiglass mount for the "rear view" camera
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 07-07-2013, 08:59 PM   #104
Put white Velcro patches of each side of the trailer and use 2 cameras so I can see both sides.
Old 07-07-2013, 10:54 PM   #105
miatared's Avatar
Well after reading this thread over the last little while I simply could not resist and just bought one off eBay for $103 - shipped to Canada from a very good ebayer. Will have to explain to SWMBO... Ah well.
Can't wait to install it. Kid in a candy store. Thanks all for sharing this find .
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 07-08-2013, 08:57 AM   #106
wmtire's Avatar
As Doering stated, the camera will rotate around a full 180 degrees (or any angle in-between), by turning to it's left. I edited a pic to show this, if you can tell
I placed one camera in a magnetic parts bowl, that I can easily place onto my trucks tailgate, to aim down at the ball/hitch, when hooking up. By being in the magnetic bowl and held in with two rubber bands, I can easily remove it, to just place the camera in other areas I may want to see in a camera. This magnetic bowl, that I got from Advance Auto has a plastic/rubber coating on the magnet itself, that will keep it from scratching the tailgate.
I have another camera mounted full-time in the rear window of my trailer, to use to see who is in my blind spot behind me when driving.
Old 07-09-2013, 06:19 PM   #107
PHS79's Avatar
Thanks alot! I just ordered a system off Ebay for $69.99 shipped to my door, for that price it was kinda hard to pass up.
nights camped:
Old 07-10-2013, 09:55 AM   #108
wmtire's Avatar
I'll say. That is cheaper than just one extra camera.
I may get another for a spare. I saw where they had 3 left on ebay for that price.
Old 07-11-2013, 07:14 AM   #109
I've been using this setup all season and let me tell you hooking up my TT is such a joy. I set it up just as the OP did with the magnetic dish and it's pretty much a one shot deal now without any help I love internet forums.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 07-13-2013, 11:04 AM   #110
Hey all, thought I would post at least a description of what I am currently using for hooking up my trailer by myself.
I have an iPhone and iPad I found an app https://itunes.apple.com/us/app/best...432791399?mt=8
I mount my iPhone in a Ram Mount, then attach it to the rear glass of my Yukon XL and I aim at my hitch area.
Then I put my iPad in the cab area to monitor.
So this is an inexpensive app, wireless. Works on wifi or Bluetooth.
I am going to attempt to mount on the side of camper when doing setup. I did have a recent issue with range on Bluetooth when I attached it to rear of camper.
Also this is clearly not a setup to leave attached while driving down the road....for obvious reasons.
If I get a chance I can send a pic of the Ram Mount...here is a link. Very handy items to use worth a look for sure.
http://www.rammount.com/
2007 Yukon XL (AKA) LAND YACHT
2002 Rockwood Roo 23ft
1998 Jeep Wangler (lifted and modified)
2008 Pontiac G6
Xtrmtj is offline   Reply With Quote
