Old 04-30-2014, 10:54 AM   #1
Master Bedroom Remodel question
Our 2014 Sunseeker 3170DS has the setup with the two tall wall cabinets on either side of the bed with the shorter overhead cabinet in the center.
Does anyone know if the tall side upper wall cabinets could be removed without affecting the center unit or, do the side cabinets hold the center in place?
The center unit is clearly screwed up into the roof but, I'm not certain those screws alone would hold the unit.
I'm considering removing the two tall upper cabinets to make sleeping in the master bed a little more comfortable. After two trips and two bumped heads in a row I feel like a change is required.
howzball is offline   Reply With Quote
Old 04-30-2014, 10:57 AM   #2
Consider shortening them?
Old 04-30-2014, 11:04 AM   #3
Kaadk's Avatar
Easiest thing to change is to just sleep upside down. DW wants to try that approach when we kick off the season this weekend.
Other than that I'd follow OC's suggestion. Why lose the whole cabinet just to get a few inches of headroom?
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 04-30-2014, 11:28 AM   #4
If you have access to a table saw you could take them down and saw enough off the 4 sides in the back so they'd be even with the center cabinet. That way you won't lose that much storage.
Old 04-30-2014, 01:38 PM   #5
I would love to cut them down, the thing is I'm not sure I can pull the sides down without the center falling out.
The good thing about cutting them is that there are only two sides, the two you can see. There's no wall side or back in either cabinet so that wouldn't take much.
What I would really prefer is being able to get the smaller center cabinet that was wall to wall and do away with both tall units. We have all the hanging clothes space we need without either of them.
Old 04-30-2014, 03:19 PM   #6
You need to look for all supporting screws for unit. Once that is done then you can see from there if you can remove some.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 04-30-2014, 03:26 PM   #7
If like most cabs in any RV they were probably glued together as a single unit on the bench and then installed as a single unit.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-30-2014, 05:33 PM   #8
Never heard that, good to know. Maybe they can have a molding made with foam in it to protect from head banging.
Old 04-30-2014, 05:56 PM   #9
AquaMan's Avatar
I'm thinking, bumping your head is merely a learning curve. A couple more times and you'll probably learn your lesson.
Seriously though, I had a similar situation in a camper years ago, and it took just a few times of hitting my head, and I learned instinctively to roll inward as I rose to get out of bed.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-01-2014, 07:34 PM   #10
I don't think anyone needs to worry about their cabinetry falling down.
I started to remove the left side tall cabinet, removed all the trim and screws that hold the unit up and this thing hasn't budged an inch.
There's apparently a couple of screws that were put in from the outside in, penetrating into the edges of the cabinetry side and bottom panel. Must have been screwed in before the outside skin of the RV was put on.
Without a multi-tool or some other way to get between the wall and the cabinet to physically cut the screw off, this thing ain't coming down. I don't know if Forest River hangs all the cabinets this way but this back unit is.
Looks like someone is going to learn to live with it.
bed, roo, modifications
