Old 09-28-2010, 03:57 PM   #1
Walke's Avatar
Mattress Storage Space Support
Mattress needs Support
To make the space under the mattress useable for my wife I installed a piece of hardwood flooring on a hinge. When you pick up the mattress aided by a small gas cylinder(in our Surveyor SP293) the leg swings into place, slide the leg ahead and it slides along the wood rail on top of the divider and the leg folds down (hinged) with the mattress. This makes the space very useful.
Ken & Judy
2012 Prime Time Lacrosse 301RLS
2014 Ford F-150 Lariat - Max. Tow - Ecoboost
Hensley Arrow Hitch
Average 50-60 nights/yr
Walke is offline   Reply With Quote
Old 09-28-2010, 07:19 PM   #2
Hipshot's Avatar
Good idea. My problem with the 2604SS was if I touched the bed it raised up. I installed a window latch to keep it closed, works great I flip the latch and the bed raises.
2010 Rockwood 2604SS
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 09-29-2010, 09:48 PM   #3
Infractee
Walke, great mod, easy simple fix.
I guess I am not understanding why the space was not useable before?? Was it just that the charged gas lift cylinders were no longer supporting the bed?
RhoZeta is offline   Reply With Quote
Old 09-30-2010, 05:43 AM   #4
Jas
Jas's Avatar
If you look at the fine print on the side of the existing lift cylinders you can plug the part number into a google search. Once you find the manufacturer, you can look at the cylinders in the same size range and pick a replacement 2 sizes bigger. I changed my 80# cylinders out for 120# cylinders and have no problem holding the dressed out bed with a 4" memory foam topper i nthe raised position.
heres the link to the thread with my cylinder info (scroll to the bottom post):
Assorted mods to my surveyor
I got the cylinders for $20 ea off of e-bay once I knew the size I needed.
2010 Surveyor SV 291
06 F250 4x4 crew cab PSD
1 DW, 1 purebred mutt, 1 ninja beagle
Nights camped in 2011: 19
Jas is offline   Reply With Quote
Old 10-08-2010, 11:28 PM   #5
did not know you could change out these cylinders for something stronger. Looks like this one is on my list as ours worked fine until we put the 3" memory foam topper on the bed. Drives my wife nuts that she cannot just raise it anymore. And speaking of foam toppers, we have a cheap mattress in our trailer and I cannot believe just how comfy these memory foam toppers make the bed. We both find it a lot more comfy than our mattress in our house and I would highly recommend them to anyone
Thanks for sharing the great tips and mods!!!
Best Wishes,
Chuck
flumpydog is offline   Reply With Quote
