10-13-2016, 11:11 AM
30+ year RV'er
Mod: Using existing Cable TV jack for Satellite
Over the years I have come across many campers that are frustrated because they have a portable satellite dish antenna, but their camper has only a “Cable TV” input located on the camper exterior. Of course, you cannot use a “Cable TV” jack for sending the signal from the portable satellite dish antenna to inside the camper – or can you? Well with a fairly simple modification you can maintain your cable-ready capability - while adding the ability to use it for a portable satellite dish antenna feed (just not at the same time). I am a retired RF professional, and offer this modification to this community because those that need it, really appreciate it! But no warranty or guarantees are expressed or implied, and any modification is done at your own risk.
As an overview, the frequencies used by a cable TV service are below 1 gigahertz (GHz). The frequencies used between the portable satellite dish antenna and the satellite receiver service are above 1 GHz. So what is needed is a device (called a diplexer) that separates the two services just before the coaxial cable from the outside connects to the antenna booster on the inside. Once separated, the cable service signal is reattached to the antenna booster and works as it did before, and the satellite dish antenna service goes to a new wall jack to which you can connect your satellite receiver. Result: if you plug in the park’s cable, it works just like it did before the modification; and, if you plug in your dish, it is available at the new jack (that you mark satellite). However, doing this requires removing/reinstalling the antenna booster, adding short cables, drilling a 5/8” hole, and installing a new coax jack plate. If you are not comfortable with this level of modification, stop here!
The supplies listed below are from Solid Signal with a parts cost of about $15. There are other places to purchase these supplies, but be sure they meet satellite signal specifications. I selected Solid Signal because it carries everything needed.
Step 1. Purchase the following items that can be found at SolidSignal.com or other sources:
(A) Quantity One: Pico Digital Custom Pre-Assembled Coaxial Cable Jumpers - Six Inch (JRG6C-6) P\N: JRG6C-6
(B) Quantity One: Pico Digital Custom Pre-Assembled Coaxial Cable Jumpers - 1ft (JRG6C-12) P\N: JRG6C-12
(C) Quantity One: Skywalker Signature Series SKY05091I Wall Plate w/single 3.0ghz F-81 Ivory* (SKY05091I) P\N: SKY05091I * As a BROWN alternative to the above, check Amazon: Datacomm 32-2024-BR 2.4 GHz Coax Wall Plate (Brown)
(D) Quantity One: Holland DPD2 Diplexer Dual Satellite Dish TV Antenna Combiner (DPD2) P\N: DPD2
(E) Quantity One: Sonora Male to Female F-Right Angle 5-Pack (HRF90-5PK) P\N: HRF90-5PK
Step 2. Disconnect the 12v fuse that powers the antenna booster and confirm that with the antenna booster on, the pilot light goes out when the fuse is pulled.
Step 3. Remove the antenna booster from the wall by removing the screws and carefully tilting the top out and lifting the unit up and cables away from the wall.
Step 4. Looking from the back of the of the antenna booster, identify the connection marked “Cable”. Typically there are three connections: Antenna; Cable; and, Set 2. The “Cable” connection is often the one in the center – but the PC board is marked, or the pigtails, depending on the model of your booster.
Step 5. Remove the coax from the “Cable” connection and attach it to the Holland DPD2 Diplexer port marked “IN/OUT” (it’s the side with only one connector).
Step 6. Attach one end of the 6” Pre-Assembled Coaxial Cable Jumper to the Holland DPD2 Diplexer port marked “VHF/UHF”. Attach the other end of the 6” Pre-Assembled Coaxial Cable Jumper to the “Cable” connector on the antenna booster. Result: You now have the original cable from the outside connected to the Holland input, and the Holland VHF/UHF output goes through the 6” coax back to where the original cable was connected to the antenna booster.
Step 7. Attach the 12” Pre-Assembled Coaxial Cable Jumper to the Holland DPD2 Diplexer port marked “SAT”.
Step 8. Locate where you want to have your new wall plate. It needs to be close enough to the antenna booster wall plate that the 12” cable jumper can reach it. If you want it further away, then you will need a longer satellite-rated RG-6 cable to replace the 12” cable jumper. Make sure there are no wires or obstructions where you plan to mount the new wall plate. The new wall plate will eventually be connected to the Holland DPD2 Diplexer, so make sure there are no obstructions blocking where this cable will go.
Step 9. Carefully drill a 5/8” hole in the CENTER of where the wall plate will be mounted. The new wall jack’s connector will fit through this hole.
Step 10. Fish the unconnected end of the 12” cable jumper through the antenna booster plate cut out (hole) and back through the 5/8” hole you just drilled. Attach the 12” cable jumper to the back side of the new wall plate connector. Result: The 12" cable jumper connects from the Holland "SAT" port, in through the antenna booster hole, out through the new wall plate hole, and connects to the back of the new wall plate. Installation Tip: Use a satellite-rated right angle connector (E above) on the back of the wall plate connector to allow for a flush fit in narrow wall cavities.
Step 11. Verify all cable connections are snug. Do not overtighten.
Step 12. Carefully work the Holland DPD2 Diplexer and cables down through the antenna booster cut out (hole). Follow this with carefully working the antenna booster unit back into its original wall mount position. Take your time – these are typically tight quarters and it may take several tries to work the extra cables back into the wall space.
Step 13. Carefully work the new wall jack and cable so that the cable goes through the 5/8” hole and the new wall plate fits snug against the wall. Use two short wood screws to keep the plate snug against the wall – be careful that the wood screws do not damage cables or other items behind the wall.
Step 14. Reinstall the fuse and verify the antenna booster pilot light comes on when activated.
All Done! If done properly, when you plug in your portable satellite dish antenna into the outside “Cable TV” jack, the signal will be sent to the new wall jack you labeled “Satellite”. The Cable and Antenna work as they always did. Enjoy.
10-13-2016, 11:19 AM
Left Coast
Good info
10-13-2016, 11:21 AM
Left Coast
Should be a 'sticky', as a lot of folks have a problem hook'n up ....
10-13-2016, 11:52 AM
That is a great solution, the magic is the diplexer. For some of us who have a switchbox, the solution is even easier. Disconnect the "cable" connection from the switchbox and connect it to the "in" on the diplexer. Connect the "sat" on the diplexer to the satellite receiver and the "uhf/vhf" to the switchbox marked cable. Run a coax from the satellite receiver "out to TV" to the switchbox "satellite" connection...and you are done!
2015 335DS
10-13-2016, 12:43 PM
Great Stuff!
Sounds like a great solution for using my ShawDirect PVR satellite receiver and thus being able to watch one channel while recording another. In the past I have had to mount a second coax connection on the outside and inside of the trailer. At least now (with our brand new trailer), using your method, I will not require an additional connection on the outside. Thanks from Canada
10-13-2016, 12:49 PM
Dahagen
Cable TV jack?
Question.....Why do you have an antenna booster on the 'cable tv' jack on the side of your RV? The antenna booster should be on the roof antenna.
For me to use the cable tv jack on my older motorhome with satellite, I simply had to change the splitter on the cable tv line to a splitter designed for satellite. The old splitter didn't let the power needed for satellite to flow to the dish and back.
10-13-2016, 12:56 PM
You can just change out the splitter to this:
cable splitter to use with satellite antenna - 5mhz-2.3ghz - Ideal brand model #85-333
Available at the big box stores for $7. As Dahagen said the old splitter will not allow the 12V to pass needed for the dish to operate.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
10-13-2016, 01:04 PM
So I have done some work in really big Sat's. We use Cat 6 coaxial wire. So my question is; if I have existing Cat 6 coaxial marked as cable, why can't I just use that for my cable. I don't see us using cable and sat at the same time.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
10-13-2016, 01:13 PM
Left Coast
You can, if there's not a splitter in cable for another tv....cable TV splitter will block signal
10-13-2016, 01:57 PM
Wait a minute. You guys move WAY too fast for me. I know it's a lot to ask...but could you please throw in some pictures??? 14 steps and not a single picture. Maybe they are simple steps to you, but not to me. I might be willing to give this a shot. But without some visual reference, I get lost pretty quick. Sorry to be such a pain in the arse, but I'm one of those people that don't get it until I can see a picture of it.
hatchet
10-13-2016, 02:01 PM
Left Coast
Is your RV satilight ready?
10-13-2016, 02:11 PM
30+ year RV'er
In RV's made in the last 10-20 years, it is common to "switch" between the antenna and the outside cable tv port by using the power switch on the antenna booster. The booster is wired to both the antenna and the cable tv port. When the booster is turned off, it switches to the cable tv port. When the booster is turned on, it switches to the antenna. Any RV wired in this typical fashion will not pass satellite through the booster switch.
10-13-2016, 02:14 PM
Thank you!
2022 Prime Time Crusader Lite 28RL
2022 Chevy Silverado 2500 Duramax/Allision
10-13-2016, 02:23 PM
Left Coast
Also, when going from antenna to cable, you need to change settings in tv....from air to cable, then do a channel scan...
10-13-2016, 08:10 PM
I'd bet you could make a living doing this for us ham handed rv'ers.
Dave Hammond
2017 FR Forester 3011 DSF
2013 Keystone Raptor TH
2013 Ford F350 Dually TV
10-14-2016, 06:45 AM
30+ year RV'er
I should add that some folks talk about a similar modification, but using a splitter in place of the diplexer. Roughly speaking, the signal level loss using the Holland diplexer is about 20%. The signal level loss using a satellite-rated splitter is just over 50%. In this application, the Holland diplexer separates two frequency bands. However, a splitter divides all band signals in half. They really serve very different purposes. If a splitter is used in this modification, then it will lose over half of the cable signal and over half of the satellite signal strengths.
10-14-2016, 10:21 AM
TV problems with roof antenna
I have a Windgard Roadstar RS 3035 roof mounted antenna on my new TT. I cannot seem to receive tv signals on it---maybe 3-4 channels. Wingard said according to them coax is hooked up correctly. I made a homemade UHF-VHF antenna and hooked it directly to tv and can pull in 35 channels.
Anyone have the same problem? What can I do to received more channels?
What I would like to do is hook my homemade antenna to the cable connection at the rear and hook the tv to the coax in the TT labeled cable. That way I would have a direct hookup to the external antenna. Any ideas how to do it or could it be done.
Very frustrating!!!
10-14-2016, 10:33 AM
Make sure that the booster switch is turned on for the antenna. Should be a green led glowing. However, that being said, the roadstar really does suck pretty much. Mine is totally unreliable.
2015 335DS
10-14-2016, 01:57 PM
Very frustrating!!!
on the manual site it identifies teh following as a check to see what channels are available and what signal strength you may have.
dtv.gov/maps
in essence it goes onto state the following:
"Using the FCC’s Mapping Tool to Help Consumers Choose a Receiving Antenna:
Guidance for Retail Sales Staff
The following instructions are intended to help retail sales staff who use the
Commission’s mapping tool to assist consumers in choosing an appropriate
television receiving antenna:
(1) Go to http://transition.fcc.gov/mb/engineering/dtvmaps/
(2) In the “Enter Location” box at the upper left side
of the page, fill in the consumer street address, city
and state, and Zip Code, and then click “Go.” This
will bring up a map showing the consumer’s location
and, to the left of the map, a list of the digital TV signals available,
color coded by signal strength at the location and listed in
descending order of signal strength at the location. The signal
strength categories are “strong,” “moderate,” “weak,” and “no
signal.”
Tip – If the tool doesn’t put the marker in the right place, click and
drag it to correct it.
(3) Clicking on the call sign for a station will
place the station’s transmitter location on the
map (along with the consumer’s location),
provide information about its signal strength at
the consumer’s address, and provide the RF
(“radio frequency”) channel used for the digital
transmission. Click on the call sign for all
stations of interest in order to map the full range
of transmitter locations that the consumer’s
antenna would need to cover. This will help to
determine whether a directional or omni-directional
antenna is appropriate, and whether an antenna rotor
might be needed. Determining the signal strength of the
weakest signal in which the consumer is interested will
help to determine the minimum receiving antenna
capability (including, possibly, an amplifier) that might be
needed. The list of RF channels will assist in determining
whether an antenna with both UHF and VHF capability is
needed. (In most cases consumers WILL want antennas
with both UHF and VHF capability). "
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
10-15-2016, 07:14 PM
I have a simple solution for my 2011 Georgetown 327DS. The "Park Cable" input in the rear compartment went directly to a switchbox which has three positions; antenna, cable, aux. I removed the cable connection to the switchbox and ran it to an A/B switch. One side of the switch (B) goes back to the FR switchbox while the other side (A) goes to the satellite system antenna power box. This allows me to use either source with a flick of the switch.
In my rig, the FR supplied amplifier is between the switchbox they supplied and the roof antenna, making setting up the system for a portable satellite dish a simple modification.
Phil
