Old 05-31-2014, 06:03 PM   #1
Modifications to Roo 183 part 1
I have made several modifications to our Roo 183 that I wanted to share.
1. Added a quickie flush to the black water tank. Add quick connects to make it faster and easier to connect and disconnect. Also don't have to worry about leaks. Click image for larger version
ID:	53932Click image for larger version
2. Added combi cams to all the out side storage. No more keys
3. Installed BAL lock arm stabilizers.
4. Siliconed plexiglass to the screen door so the dog does not rip the screen when he taps to go in or out.
5. Extended the fresh water drain to the side. No more crawling under the trailer to drain the tank. Used a clear tube so that I can see if any water remains. Mounted the drain cock to the side with a 3/4 inch pipe support.
6. Installed LED Lights in the outside storage. Operated by a switch by the water filter. Tapped into the front light that has constant power while on battery or shore power.
7. Installed LED under the awning and under the first step. I ran the wires through the channels in the floor that forest river uses to run their wiring. I ran the wires all the way up to the control center and installed a JR switch.
ID:	53940Click image for larger version
ID:	53941 Click image for larger version
I have a few more mods which I will list in part 2.
___________________
Rick, Angie & MAJ
2014 Nissan Pathfinder
2014 Rockwood Roo 183
zoomer32ca is offline   Reply With Quote
Old 05-31-2014, 06:12 PM   #2
Y'all dun good! Very professional work.
Old 05-31-2014, 06:16 PM   #3
fonzie's Avatar
Nice mods that you did. One advice would be hopefully you are using a dedicated garden hose for your black tank flush as it does not have a vacuum breaker valve in line with flusher to prevent contamination from reverse water flow from black tank to your water hose. You should be using separate water hose for city hook up and black tank flush.
Fonzie
Old 05-31-2014, 06:19 PM   #4
I would like to see more on how you hooked up the fresh water tank drain. Looks like a good idea.
wellcoman is offline   Reply With Quote
Old 05-31-2014, 07:58 PM   #5
Fresh Water detail
wellcoman,
I have included more pictures for you. The piping for the fresh water drain is PEX 1/2 inch pipe thread. I tried to find the same elbow that forest river uses because it is low profile. I had no luck so I robbed it from the air intake and re-plumbed the air intake using PVC and PEX. I needed low profile because the drain on the side had to be lower and I did not want to go to low.
I threaded the drain cock (which I bought from local RV store) to a PVC coupler. I bought a 3/4 inch copper pipe hanger from home depot and PEX 1/2 inch to insert fitting. I screwed the PEX fitting in the PVC which sandwiches the hanger. I used 3/8 inch clear tubing so I could see if there was water in the line. The connections to the PEX insert is just 1/2 inch PEX clamps.
I added a rubber spacer between the frame and the pipe hanger to make the drain about 1/4 inch lower than the bottom of the tank.
I used tread tape on all the treads as well as a little petroleum jelly. It is the petroleum jelly that guarantees a leak free connection.
ID:	53968Click image for larger version
ID:	53969Click image for larger version
ID:	53970Click image for larger version
___________________
Rick, Angie & MAJ
Old 05-31-2014, 08:02 PM   #6
Yes, I do use a dedicated hose. The quickie flush also has a back flow preventer.
___________________
Rick, Angie & MAJ
Old 06-02-2014, 08:13 AM   #7
___________________
Rick, Angie & MAJ
Old 06-02-2014, 08:17 AM   #8
wellcoman,
ID:	54112Click image for larger version
ID:	54113Click image for larger version
ID:	54114Click image for larger version
___________________
Rick, Angie & MAJ
Old 06-02-2014, 08:48 AM   #9
Take The Road Less Travld
MuddauberE's Avatar
I'm just replying to this one to keep it in my subscribed list . I love these mods.
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 06-02-2014, 05:59 PM   #10
What is the switch part number? I looked and couldn't really find it.
Sent from my SGH-I337M using Forest River Forums mobile app
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
Quasipato is offline   Reply With Quote
Old 06-02-2014, 06:11 PM   #11
Ret E-9 Anchor-clanker
donanddona's Avatar
Yes sir, Great job. I really like the led's in the storage area.
donanddona is offline   Reply With Quote
Old 06-02-2014, 06:59 PM   #12
It is just a JR products switch. I bought it from my local RV Dealer. The JR products manufacturer number is 13405.
___________________
Rick, Angie & MAJ
Old 06-08-2014, 02:31 PM   #13
o
bobuk1's Avatar
Sent from my SCH-I545 using Forest River Forums mobile app
bobuk1 is offline   Reply With Quote
cat, modifications, roo
