Old 09-26-2010, 10:27 AM   #21
yvesm's Avatar
Storm Door
Being home for a few weeks I decided to make Plexiglas storm panels for the screen door so that I can have the outside door open during colder weather so that the sunlight comes in. I used Plexiglas panels that fit nicely into the small groove on the outside of the door. Once the panels are made to size they snap right in. The small notch in the upper panel (both lower edges) allows the panel to be snapped in to the edges and then pushed up into the upper groove.
ID:	3520   Click image for larger version
ID:	3521   Click image for larger version
ID:	3522   Click image for larger version
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 10-03-2010, 10:08 AM   #22
DCRC's Avatar
Originally Posted by yvesm View Post
This weekend I am removing the rear jacks so that I can install a proper cross brace so that the trailer does not move at the rear. Some some reason Forest River put in a 1" x 1" x 3/32'' thick (.09375") angle to support the back side of the jacks. when you put weight on the jack the angle bends up! So why can't they do it right, who knows. I will post images
You would think FR woud have gotten feedback on this and corrected it. My 09 Windjammer has the same cross brace as well and it is a joke.
I've replaced the front one already with 2 X 3 tubing and added the BAL lockk bar struts and it has made a huge difference. Planning on replacing the back crossbrace and adding the struts as well.
Was planning on going with scissor jacks on the back, but I I think the "C" jacks work good on this lightweight trailer when properly installed and braced.
08 Toyota Tundra 5.7
09 Rockwood Windjammer 3001W
DCRC is offline   Reply With Quote
Old 10-03-2010, 05:59 PM   #23
WestCoastRV'er's Avatar
Nice
I was planning on doing this myself over the next few months.
WestCoastRV'er is offline   Reply With Quote
Old 10-03-2010, 10:51 PM   #24
DCRC's Avatar
Originally Posted by milzat View Post
I'm doing the same, and replacing the factory stabilizers with scissor jacks.
Also, gonna add Homemade(shop built) Jack Stabilizer Bars similar to the ones in the photo. Check out what Neil did to stop the shaking.
Ok, I replaced the front flimsy crossmember with 2x3 sq tubing and added the BAL lockbars and made a huge difference. Just about as good as when I had the front sitting on jack stands!
Just finished doing the same in the rear and only notice a slight improvement. Think I am going to shim the acme screws on the "C" jacks like "dunnnc" did in the link you provided and see if that helps some. I think you could make the shim like he did, or remove the pin and and completly unscrew the screw and just place a washer on the shaft to take up the space. Might see if I can come up with a bronze bushing to make it tight.
Problem with the rear is that there is not near as much weight and you don't have the "A frame" stiffening up the trailer frame rails like you do in the front.
When tightening the front you feel a noticable resistance. When tighening the rear it just starts lifting the trailer and keeps going. Either flexing the frame or unloading the suspension.
What you end up with is a trailer that is rock solid on each end and springy in the middle. Some small scissors jacks in the middle of the trailer would basically lock out the suspension and make for a very solid and stable trailer.
sorry to jack your thread.
Old 10-04-2010, 09:11 AM   #25
annamarie's Avatar
Unhappy Microwave appliance
Here is the first mod to our 2011 2902SS. A light above the kitchen sink.
I see that you have a stianless steel microwave oven. Did it come with the stainless steel appliance pkg.? We ordered that and everything but the microwave came in stainless steel. The company said they didn't have a microwave in it. ?????
annamarie is offline   Reply With Quote
Old 10-04-2010, 10:00 AM   #26
yvesm's Avatar
The microwave was part of the stainless steel package, don't let them cheat you out of it. Good luck with your Forest River Product!
Old 10-31-2010, 06:39 PM   #27
yvesm's Avatar
Faucet Upgrades
Upgraded the faucets in our 2902ss.
ID:	3769   Click image for larger version
Old 10-31-2010, 06:55 PM   #28
The Old Man
Willis's Avatar
Awesome...I did that on my previous TT and SOOOO want to do that on my new Flagstaff.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 02-06-2011, 03:21 PM   #29
yvesm's Avatar
Steady Fast
Today I ordered the Steady Fast system Welcome to Steady fast I should have it by the end of the week. I will also be replacing the factory stabilizers with 6 BAL scissor stabilizers, 2 at the front, 2 at the rear and 2 behind the wheels to take out the bounce. The 2 jacks behind the wheels will eliminate the 2 screw jacks that I have been using. I will be making the upgrades when the 3+ feet of snow melt, probably in late March. I will post pictures of the work (probably under a new thread as this one is getting old).
Old 02-07-2011, 12:39 PM   #30
Yvesm were did you purchase the Upgraded the faucets from.
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
browne02 is offline   Reply With Quote
