01-06-2018, 07:08 PM
Mopeka LPG Tank Check on Horizontal Tank
I purchased a Mopeka tank check to install on my 2401R since neither of my gauges agree with each other and having the low level warning sounded like a great idea.
I thought when I first purchased it I could just Zip tie it to the tank and all would be well but once it arrived I found that really wasn't going to work well at all. Fortunately I own a 3d printer and was able to print up an adapter that made attaching it to the tank easy and helped protect it at the same time.
Can't wait to get back out camping and see how well this works.
01-06-2018, 07:52 PM
I may be all wet here, but I believe the sensors are calibrated to a 20# tank and are supposed to be mounted on the bottom of one. I was going to invest in them as well, but after talking to Mopeka ... learned that they were calibrated to a 20# tank and I have 30's. Mopeka said it would work, but the 30# tank would show full longer than it really was. Too much money for kinda sorta know the tank level.
01-06-2018, 08:07 PM
Does that zip tie go over the relief valve on that tank?
01-06-2018, 08:08 PM
As far as I know that was for the external monitor which was updated to allow monitoring of 20/30/40# tanks. I just purchased a single sensor and use my cell phone which is the only way to monitor a horizontal tank. It may not be dead accurate but it will let me know when it's time to refill before I run out.
01-06-2018, 08:11 PM
It does go over it but its not interfering or touching it and it's easy enough to cut it off if necessary.
01-06-2018, 08:16 PM
Mine just connects to the bottom of each tank with magnets. Works fine.
FROG AR-0019-242
01-06-2018, 08:25 PM
Glad to hear it, I found on mine that with the rounded bottom the contact was not very good and trying to use a zip strap to secure it cocked the sensor and gave me bad readings.
01-06-2018, 09:05 PM
A dab of petroleum jelly on the sensor helps ensure a good connection. I found that centering the sensor "exactly" on the bottom of the curve on the horizontal tank is important for good readings.
01-06-2018, 09:31 PM
This is the second post this week I found talking gas tanks, change over valves. and gauges. What ever happened to the good old days of using our brains and keeping it simple. Two tanks, one goes empty, pilot light goes out. Remove the empty, change over valve, light the pilot, we're done. How did I get to be 66 years old without electronic gadgets how did my mom to it to 82!!!! I'm done.
01-06-2018, 10:11 PM
I hear ya cavie. We got one of those robotic vacuum cleaners for Christmas. Now all I have to do is tell Alexa to start the thing and off it goes.
Aint technology grand???
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
01-07-2018, 04:35 PM
LP Tank gauge
A little warm water on the tank in the morning, see where the frost line is. Most accurate gauge of them all.
01-07-2018, 04:39 PM
I have installed this in my 2502KS as well, have 2 30# tanks and just followed the installation instructions. Make sure the magnets are underneath on the center of the tanks . I use the monitor in my unit to check levels and it works just fine. I thought of using my cell phone but decided that wasn’t the best application for me. I do respect the post that mentioned just using common sense and switching tanks when one was empty, but sometimes common sense isn’t applied .
01-07-2018, 06:49 PM
One LP tank seems to run out at the wrong time, early in the morning when it’s cold outside. If I know one tank is getting low I may take the tank out to get the tank refilled when it’s convenient or cheaper.
01-08-2018, 08:21 PM
I live full time and have 5 30 lbs tanks. I have the sensors on mine. When one gets empty and it auto switches I go out and replace the empty one. When 4 get empty I go get them refilled. Have been using the sensors for 18 months and they work great.
I have five sensors, two on me 38EL, two one my Toyhauler and one on my gas grill. I had an issue with two of the sensors last summer. I called them and they had me mail them back. They found the issue and replaced them at no charge. Great customer service. I would not be without them.
Brian & Terri
Samson (Chocolate Pom)
Full timers
2008 F350
2017 CC Champagne 38EL
2006 Salem Sport 32 SRV Toy Hauler (still have)
01-08-2018, 08:53 PM
I have one that I can’t get to work, I have changed the battery. I’ll call the company
01-08-2018, 10:22 PM
That is same issue I had. Said they had Been crushed. I had the rubber feet then, when they sent me the new ones they included the new aluminum feet at no charge also.
Brian & Terri
Full timers
2008 F350
