Old 09-21-2019, 10:56 AM   #1
More Counter Space!
I was looking for more counter space in my 2018 Shockwave T28RQDX Toyhauler. I found these steel powdercoated flip up shelves from Harbor Freight for the Geberal tool boxes worked out perfect & were cheap in comparison to some of the other options out there. 18"x18". Butted up against the front corner trim it clears the slide by 1/4". Remove the oven. Add the backer board. Drill pattern & mount with carriage bolts.
ID:	215463   Click image for larger version
ID:	215464   Click image for larger version
ID:	215465   Click image for larger version
ID:	215466   Click image for larger version
Bryandenny71 is offline   Reply With Quote
Old 09-21-2019, 11:26 AM   #2
Brother Les's Avatar
I am a little confused about what I am looking at?
Brother Les
Old 09-21-2019, 12:01 PM   #3
Tilt your head. Every picture but the last one loaded sideways. Last pic shows the backer board I installed.
It's a flip up shelf from harbor freight attached to the counter sidewall next to the oven.
ID:	215476   Click image for larger version
ID:	215477   Click image for larger version
Old 09-21-2019, 02:59 PM   #4
https://www.harborfreight.com/foldin...art-63470.html
Here's the side tray.
Old 09-23-2019, 08:48 PM   #5
Nice!! I’m going to do this. I was going to make out of wood but this seems way better. Nice work!!
WolfPup2018 is offline   Reply With Quote
Old 09-24-2019, 11:36 AM   #6
Make sure to butt the shelf all the way up again the outer trim to clear the slide. & you will need longer carriage bolts. I went with 3/8" x 1-1/2". When you match drill the pattern, two bolts will go thru the outer framers joint strip & the other two will just go thru the backer board.
