Old 08-01-2010, 08:58 PM   #11
milzat's Avatar
Originally Posted by Bayouownbeer View Post
Mike whats the benefit of the new landing gear locks?
Benefit ??? Spring loaded.
No need to unlatch and remove latch pins, then installing them again. Just pull the spring loaded level and let the jack leg fly.
Time saved, is time drinking your favorite adult beverage.
Benefits galore............................
milzat is offline   Reply With Quote
Old 08-01-2010, 09:06 PM   #12
Bayouownbeer's Avatar
GOTCHA!!
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 08-13-2010, 10:47 AM   #13
milzat, I notice you have good sized pads made out of lumber under your landing gear legs. To me that is a must - did a similar thing when we had a 5er.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 08-13-2010, 11:51 AM   #14
milzat's Avatar
The previous owner made 4 of those, using three 12"X12" treater boards, glued and screwed together.
I'm going to attach a handle on each one.
Old 08-13-2010, 09:10 PM   #15
Or drop all the way to the ground and fall out that's always fun trying to get them back in.
I've learned put the blocks under them BEFORE pulling the pin. It doesn't snap back that fast
2011 Sierra 35 Loft TreeHouse
2006 Dodge 3500
Better Photo
Mowat is offline   Reply With Quote
Old 08-13-2010, 09:17 PM   #16
milzat's Avatar
Mowat,
That's a big 10:4
Old 08-22-2010, 08:40 PM   #17
Mike,
See you have the Firestone Air bags...I have just bought an 06 RWOOD 828SS and pull it with a 1500 Z71..could you tell a noticeable improvement with any chucking issues after the airbags were added.
kscr4 is offline   Reply With Quote
Old 08-22-2010, 08:59 PM   #18
milzat's Avatar
kscr4,
I installed the air bags before picking up the trailer. Started with 10psi. Good ride, but a little bouncing. Next trip went to 20psi. Better ride. Then 50psi & now 60psi. It rode better each time the pressure was increased. Bouncing(chucking) was less with every increase of pressure also. With 60psi, it's hardly noticeable. Even with the trailer un-hitched, the truck rides good with 60psi.
Old 08-22-2010, 09:08 PM   #19
Sounds like what I'm looking for. It's not to aggravating for me but the better half is a little uncomfortable with the ride. Are you running class D tires? And what PSI on your tires?
Old 08-22-2010, 09:30 PM   #20
milzat's Avatar
Load rating D.
40 psi on truck, 50 psi on trailer.
What year is your truck?
I've got a '06 and the Firestone air bags didn't fit as stated in the instructions. I triple checked the part number per application. I had to mount them rear of the axle housing.
