Old 02-20-2009, 06:39 PM   #1
Mosquito netting
Hello-
I have been trying to find the best product/method to install mosquito netting on to the awning so we can sit out in peace. Any advice? Are there kits available?
What other items do you have that have made it more enjoyable to sit outside?
Allison
2008 Flagstaff 831KRSS
Dodge Ram 1500
dufchick is offline   Reply With Quote
Old 02-20-2009, 08:41 PM   #2
froglegs's Avatar
I would use the shading material that is used to cover greenhouses for shade in the hot months. You can find it at greenhouse supply houses. It comes at any length and 12' to 40' wide. I believe it to be your cheapest way out. Good Luck!
2000 F-150 4x4 sc,off road pkg,Tow Pkg,5.4,3.73TL,2007 Flagstaff 8524RLS,and One Happy Maltese! See You Down The Road!!!
froglegs is offline   Reply With Quote
Old 02-21-2009, 07:37 AM   #3
Thank you! I would never have thought of that, I will search for that material today. That would certainly give us privacy and keep the bugs away.
Thanks!
Allison
Dodge Ram 1500
Old 02-21-2009, 08:07 AM   #4
milzat's Avatar
A&E Patty O'Room
http://www.pplmotorhomes.com/parts/r...tty-o-room.htm
Dometic A&E screen room
http://www2.dometicusa.com/awnings.php?id=screen
milzat is offline   Reply With Quote
Old 02-21-2009, 09:47 PM   #5
Originally Posted by milzat View Post
Wow, well that is a beautiful unit but significantly more than I wanted to spend! I found a couple of things online that I will have to either attach hooks or grommets to, or double sided velcro, but I am unsure how the awning will roll back up with double sided velcro attached. Hooks I can simply remove, but velcro is not easy to remove.
I found these items:
http://www.fabricdirect.com/acatalog...ing-Ivory.html
http://www.mosquitocurtains.com/home...o-netting.html
Dodge Ram 1500
