Old 12-07-2019, 01:01 PM   #1
Mounting antenna on roof.
I bought a haloview MC7108 for my toy hauler but found the signal lag and freezing up really bad so I ordered the separate antenna with the magnetic base that I tried on the monitor in the truck but still lagged and froze up. I tried it on the top of the trailer in front of the ac about 8' from the rear and it works great. I am looking for suggestions on what adhesive to use to mount either a piece of either stainless steel or another magnet with, I'm thinking, Diecor or Lexal. Any other ideas or suggestions?
Joe
2020 Grey Wolf 26RR
2011 F150 Eco Boost Lariat
Its All Fun And Games Until The Flying Monkeys Show Up
joeobx is offline   Reply With Quote
Old 12-07-2019, 08:00 PM   #2
Retired Panpsychist
Theo's Avatar
Will you get a good signal with the antenna on the top of the AC enclosure? If so, you could mount a piece of stainless with screws on the plastic enclosure and avoid messing with the roof all together. Of course, height will be increased but, perhaps, so will the signal to the monitor.
Just spitballing...
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A)
Theo is online now   Reply With Quote
Old 12-08-2019, 03:08 AM   #3
CincyGus's Avatar
I've seen some Youtube videos of people mounting a slim metal plate to a rubber roof using eternabond tape. once that stuff is down on a cleaned surface, it's there solidly and for a long time unless you forcefully remove it with a heat gun. Believe it was a youtube channel that tests a lot of different systems (cellular boosters, wifi boosters, etc.) and wanted a plate that would support magnetic bases for their antennas just as you do.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 12-08-2019, 02:33 PM   #4
This may be the route I go. I dont want to mount it to the ac cover as I am a little concerned about the height.
2020 Grey Wolf 26RR
Old 12-08-2019, 08:52 PM   #5
TowPro's Avatar
One problem, I don't think most stainless steel is magnetic
2019 Forest River Forester MBS 2401R
TowPro is online now   Reply With Quote
Old 12-08-2019, 09:49 PM   #6
Quite a bit of stainless steels are magnetic. Just take a magnet with you when "shopping".
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 12-08-2019, 10:40 PM   #7
I just installed the Haloview, and same "issue". I was thinking of just mounting a small piece of metal, with some screws through the plywood, and then combo of butyl tape and lap sealant.
Think the better idea is eternabond.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is online now   Reply With Quote
Old 12-09-2019, 01:57 PM   #8
Go to Goodwill and get a 12" pizza pan. Eternabond it to the roof and be done with it. 12" circle gives a good ground plane for the antenna.
AFDON is offline   Reply With Quote
Old 12-09-2019, 02:11 PM   #9
rracer5's Avatar
X2. Antennas usually need a ground plane and the vertical "stick" to receive optimum signals. When you stick the magnetic base of the antenna to metal, the metal (car/truck) body becomes the ground plane. That's why I was finding it hard to believe that just standing it on the plywood/rubber roof improved your reception. The only reason I could figure is that the antenna then had no obstructions between the rear camera & the monitor in the truck.
So, I'm assuming that if it has a magnetic mount to stick to metal, that metal becomes the ground plane part of the whole setup.
Below copied from wearecb.com (CB World)
What is a Ground Plane?
A ground plane, also called counter poise, is the reflective unit in the system, while the antenna is the reactive unit. Most mobile antenna installations use the metal part of the vehicle such as the chassis and the body for the ground plane. There are systems that don't require ground planes; those use the shield in the coaxial cable as a substitute. Be aware that the hardware for the ground plane and no ground plane systems are not interchangeable.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-10-2019, 07:59 PM   #10
Who Dares, Wins
doc73's Avatar
I eternabonded a metal baking sheet to my roof for our Wifi Booster
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-11-2019, 11:40 AM   #11
When I put the antenna in front of the ac to test i just used a 3M removable strip to hold it down so I think a small piece of SS will work. I don't know if it would be a real concern but a large piece would seem like it would draw a lot of heat, maybe paint it white?
2020 Grey Wolf 26RR
Old 12-11-2019, 04:03 PM   #12
Who Dares, Wins
doc73's Avatar
I painted mine gray, but white would work. Just look up how much of a "ground plane" you will need for the antenna to do its best.
2015 ChevyHD D-Max
Old 12-12-2019, 08:43 PM   #13
Yes only 308 stainless has any magnet to it and that's not much I have used the tape and works a long time
Mileskeller2512 is offline   Reply With Quote
antenna, mount, roo, roof
