Old 07-12-2015, 07:29 PM   #1
jimacamper's Avatar
Mounting LED strip
Mounting an LED strip on the rain channel underneath the awning (on a Georgetown). I've got the option to have the LEDs project outward from the coach or directly down on the bottom of that channel. What have people done. I don't know if shooting downward from the channel will illuminate the area well enough or if I should have an outward. I don't have the awning out all the time so don't want to be dependent on reflecting the light.
Georgetown XL 350ts
Past:
LivinLite Quick silver
Coleman 12' Pop up
Jayco X23B
jimacamper is offline   Reply With Quote
Old 07-12-2015, 07:54 PM   #2
Adony's Avatar
down
I have had them both ways and down is the best on my TT. The more protection, the better..
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 07-12-2015, 08:16 PM   #3
jimacamper's Avatar
That's what I've been thinking but a day before I plan to do the install trying to think through any stupid moves :-) Thanks! Anyone else?
Georgetown XL 350ts
Past:
Coleman 12' Pop up
Jayco X23B
Old 07-12-2015, 08:36 PM   #4
Adony's Avatar
plan ahead
The first strip (s) I installed I used the extra sticky 3-m trim tape as I didn't trust the double sided tape that came on the strips. After several months of use, many of the led's failed so I had to replace everything. Getting the old one off and removing the trim tape turned out to be an expensive and time intensive chore. I mounted the new strip using industrial velcro.. so far so good and they haven't failed in over a year, but if they do...velcro will make the removal a snap...
Ted
2010 T25KS Wildwood
2006 F-250 SD
Old 07-12-2015, 08:38 PM   #5
jimacamper's Avatar
Where does one get industrial velcro?
Georgetown XL 350ts
Past:
Coleman 12' Pop up
Jayco X23B
Old 07-12-2015, 08:50 PM   #6
Kaadk's Avatar
I did pointing down on my TT. Figured that way for two reasons:
1) Thought by projecting them down, they'll work better when the awning's rolled up.
2) Thought it'd be less obtrusive to the look of the trailer if they're mounted on the rain gutter vs the side of the trailer.
Course, you can always have someone help you hold them up both ways to figure out what works best for you.
Old 07-16-2015, 08:52 PM   #7
jimacamper's Avatar
Got hem up last night. Used 3M auto mounting tape. That stuff those strips come on is horribly cheap. Hopefully they last a long time and But it wasn't too bad anyway.
ID:	83112Click image for larger version
Georgetown XL 350ts
Past:
Coleman 12' Pop up
Jayco X23B
Old 07-16-2015, 08:53 PM   #8
jimacamper's Avatar
There is one above and one below. I had only intended the one but the RGB strip doesn't do a nice white so I put it below and got a RGBW for above. Powered by the porch light.
Georgetown XL 350ts
Past:
Coleman 12' Pop up
Jayco X23B
Old 07-16-2015, 09:42 PM   #9
Left Coast
When (if) tape fails, they make an aluminum channel with choice of clear or frosted cover that makes replacement a whole lot easier.
Old 07-16-2015, 10:22 PM   #10
Mine came with them, every foot or so forest river put a thin bead of silicone over them in case the 3m tape fails. I added a white next to the factory blue and followed suit with the clear silicone. The bead of silicone is an 8th inch wide and about an inch tall crossing the light strip.
Simplewon is offline   Reply With Quote
Old 07-16-2015, 10:30 PM   #11
Left Coast
I also have'em in the awning roller...there, it was necessary to use silicone every 8/10 inches to retain.
Old 07-23-2015, 01:51 PM   #12
Fireman
Send a message via AIM to dutch
Jim,
The LED looks great. One question I have where do you get the electric for that out there? I was thinking of doing that too but can not figure out how I can get elect to them lights.
2013 Georgetown XL 378
Toad 2012 Honda Civic
Dutch & Kathie & shitzue Buddy
US Air Force Retire SMS
dutch is offline   Reply With Quote
mount, led
