Mounting Solution for Furrion Monitor for Ram
Purchased the 7 inch Furrion Camera system, with all the cameras (back, side and door) for the new Sandpiper. Now, where to mount the giant screen in the 2017 Ram? Perhaps this solution will work for you.
When you buy the camera they give you a suction cup window mount and a table top mount, but this monitor is too big to mount in my front window without blocking my view or becoming distractive. So, after much poking around and a little thinking, I came up with this simple solution. I noticed this truck had an upper and lower glove box. The upper box has a grove around door that was plenty deep to accept the flange of a small bracket. I simply glued the bracket to the monitor and slid it in the upper glove box groove. The unit seem to be tight enough not to slide around, so I think I'm good. I suppose I could add a lower strap if it becomes a problem.
The beauty of this solution is that the monitor is easily taken down, easily visible with a quick glance, and rides in front of my wife who advises me on lane changes! It was also essentially free, which is important because you won't have any money left if you buy all this stuff.
