09-05-2014, 08:50 AM
#21
Irish Spring everywhere (smells nice too) and ultra sonics.
The thing with the ultra sonic is that it does not go through walls. Think of it like a flashlight. Any where in range of the front is illuminated", but if they can get into a void area, they'll be safe from the noise. I put one on an extension cord under the sink.
2011 PrimeTime Tracer 2600rls
08-08-2020, 03:32 PM
#22
Has anyone tried this?
https://www.riteaid.com/shop/rodent-...old%20Supplies
I know this is an old thread, but this should revive it. I can't really seal my storage building from adjacent units, so as a precaution, I put some glue traps out in strategic locations. I would probably need about 100 to cover every likely access point, and then I still can't get them all.
Anyway, much to my dismay, one of my glue traps captured a mouse.
I don't see any evidence that they've been around the RV, and I want to keep it that way.
There are bait stations around the outside of the building, but I don't know how often they're maintained. I'm hesitant to put bait inside, because once poisoned, rodents do anything to get water. I've seen them chew through every hose on a washing machine, including the pump housing to get the little bit of water. They don't seem to be able to sense the pressurized water in fill hoses, oddly.
Anyway, my point is that they'll chew up RV hoses.
I've heard of guys using sheet metal encircling landing gear to keep them out of airplanes, but the RV is only about 8" off the ground.
If these peppermint sprays work, they would be very convenient.
The only other thing I can think of is putting a bunch of glue traps all the way around the tires. I think we just have field mice, which are smaller, and not rats.
2020 Sunseeker 2860DS
08-08-2020, 08:34 PM
#23
I put a mouse trap on top of each tire and haven’t had a mouse in my RV since. I’ve trapped 6 mice since doing this.
2017 Forester MBS 2401S
08-08-2020, 08:42 PM
#24
Interesting technique. I think we are lucky in that our neighbor has an outdoor cat and our trailer is parked close to his house. It is clear that under the previous owner our trailer had a mouse problem but I think this cat is really the key to keeping us mouse free. In the winter we do try to remove all the bedding and any possible food sources too eliminate things that are enticing or good nesting places. I’m getting queasy just writing this.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
08-08-2020, 08:47 PM
#25
Thanks. My wife unit mentioned that she saw someone put glue traps on top of their tires, so that's what I did.
I also put a couple of spider traps on the rear bumper. We have the largest black widows I've ever seen here.
08-08-2020, 09:49 PM
#26
Electronic pest plug ins did zilch for me
08-13-2020, 04:56 PM
#27
We use regular traps, sticky traps, & put several drops of peppermint on cotton balls placed on small plates around the trailer. Have had no mice since doing this.
09-24-2020, 12:25 PM
#28
How about irsih Spring soap for rodents I have heard a lot of seasoned RV’s sing it’s praises?
09-24-2020, 12:29 PM
#29
The mice found the Irish Spring quite tasty in my neighbors 2008 Montana last winter in storage.
09-24-2020, 12:47 PM
#30
Our RV is stored inside and we put those sticky glue boards from Terminix around the tires. They work well!
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
09-24-2020, 01:04 PM
#31
If you use steel wool, make sure it's stainless steel wool so you don't have a problem with it rusting in the future.
09-24-2020, 01:26 PM
#32
I'm not sure what actually works
I use this high-powered Victor ultra-sonic unit, with all cupboard doors open, liberal Bounce dryer sheets and opened boxes of Irish Spring soap... bought a whole case of soap at Costco a few years ago. I also bought a 3-4# bag of some kind of poison mouse bait and spread that around the trailer tires. My detached garage area is ate up with mice, but the trailer has been OK.
2014 Shamrock 183
09-24-2020, 03:11 PM
#33
nothing works like decon !!!
motorhomes are the hardest to seal up . TT and 5th wheels allow for access to all possible entry points . 6 yrs ago droped my underbelly when unit was brand new . added foam board insulation , tied up wires and routed water lines and insulated and secured . when re-installing under belly spray foam around the entire edge as i re-secured to frame then spay foam in all entry points . and not one mouse in 6yrs or rat, or much for bugs either
09-25-2020, 12:24 PM
#34
Retired Panpsychist
Shawn Woods' YouTube channel " Mousetrap Mondays" is a great source for information on the efficacy of the various mouse deterrent (sub)urban legends. He actually tests the various myths and records video of the results. This tends to weed-out all the false info.
Of the many deterrents I have heard about, one of the only one that Shawn has found to be effective is the use of mint oil. HERE is the video of his test.
He proves the following to be absolutely ineffective:
- Dryer Sheets - mice used them for nesting;
- Mothballs - mice ignored a whole box of them;
- Irish Spring Soap - mice actually ate it;
- Fox & Wolf Urine (!) - mice ignored;
- Food Seasoned w/Peppers - mice ate it.
So, regarding rodents, you might want to pick up some mint-based repellent.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
09-27-2020, 09:54 PM
#35
Originally Posted by Windywest
We use Freshcab rodent packs, one box of 4 packs does us all year. Available online or at most hardware and farm supply outlets.
Just ordered some. Hoping that does the job.
