Old 08-27-2014, 08:30 PM   #1
Alberta8311ss's Avatar
Mouse proofing
Name:	ImageUploadedByForest River Forums1409188971.809478.jpg
As we have owned other rv's in the past one thing I have learned is to get the holes under the rv filled before it gets too close to the cold winter days when rodents are looking to take up residence. I pulled the outside fridge out and removed the shelf it sat on to check the penetrations through the floor for the water lines etc. I was surprised to find chewed wiring already! Anyways after 3 cans of spray foam and a box of steel wool I hope I'm not going to be surprised come spring time to find turds everywhere inside. I must say there were a lot of holes that needed to be filled in the floor and underneath leading into the enclosed belly.Click image for larger version
Name:	ImageUploadedByForest River Forums1409189421.504916.jpg
Alberta8311ss is offline   Reply With Quote
Old 08-27-2014, 08:35 PM   #2
vinmaker's Avatar
Yep. So true. that is one of the first things I am gonna do to my unit when I get it. Put the halogen work lights on inside when it is dark out and then crawl underneath to see the holes. Works every time.
Vin
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-31-2014, 06:59 PM   #3
dj3spots's Avatar
Has anyone tried using the electronic or ultrasonic pest repellers? If so, which brand did you use? Did it do the job?
dj3spots is offline   Reply With Quote
Old 08-31-2014, 07:33 PM   #4
dj3spots: I've used the ultrasonic pest controllers and they work (for me, anyway). I've not had a problem since I started using them 15-20 yrs. ago. The problem most people have is they buy one or two or a pack, plug them in, and say they don't work. You need to place them in almost (if not) all your outlets as the ultrasound does not go through furniture, walls, etc. I have one in ALL my outlets in my house. I buy them with an additional electric outlet on the side--that way I don't lose an outlet. I also buy the ones with a pulsating sound (not steady, as mice will learn to avoid them). OF COURSE you should begin the process by sealing any places you think mice can get in and do not let food or crumbs around. Personally, I swear by them. Whatever you do, please don't use the sticky traps as they are as cruel as can be--just Google "sticky traps and cruel". As far as poisons, that can kill more than just mice--other animals (cats, dogs, etc.) that may eat the poison or eat something through the "food chain". For my PUP (which I am getting HOPEFULLY soon!) I plan on using cotton balls soaked in peppermint oil (NOT EXTRACT) and these from Amazon.com: http://www.amazon.com/dp/B0021LWPPY/...WAN5BSKY&psc=1
brewjaz is offline   Reply With Quote
Old 08-31-2014, 07:35 PM   #5
dj3spots: I use these and another brand that's not made anymore: http://www.amazon.com/Bell-Howell-Ul...+pest+repeller
Old 08-31-2014, 07:40 PM   #6
dj3spots's Avatar
Thanks brewjaz! I use the peppermint soaked cotton balls in trailer. Was thinking the electric pest repellers would be added deterrent. We live rural. That being said there are always mice and other varmints around. Mice get into the house but don't last long. My 4 legged pest repellers take care of that prob. Also make the mistake of taking an extended trip and boarding the cats. We have a lovely problem with mice when we returned. Next time I'll set up the electric pest repellers, so nice to know they work in the house.
Old 08-31-2014, 07:49 PM   #7
hkreck's Avatar
I had mouse in my MH about a month ago, went in with a gopher smoke bomb setting off the smoke detector and smoked up the place good. Next opened up the area where the nest was being build and cleaned it out. Then put Bounce dryer sheets down in every drawer and cabinet inside and out. Added some traps and waited. So far have not seen any more signs of the little devils. Also went under the rig and sealed up and few opening that I hadn't seen before.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 08-31-2014, 07:52 PM   #8
dj3spots's Avatar
Yeah, heard about the bounce dryer sheets being effective. Glad it works for you. But, I'm allergic to perfume/fragrances.
Old 08-31-2014, 07:57 PM   #9
hkreck's Avatar
It does leave a fragrance in the MH but I've smelled worst things.:-}
Henry & Tena
2013 Solera 24S
The Great Escape
Old 08-31-2014, 08:29 PM   #10
Boss Hoss's Avatar
Bounce
We'll use a whole box every winter,We throw them everywhere.Also i put a tub of dehumidifier in the sink to absorb the winter condensation.Works well.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
roo, roof
