Old 09-29-2015, 12:52 PM   #1
Jeffco, MO
tedstr's Avatar
Mouse Trail Mod
MY DW told me she could smell a mouse in a relatively new Silverback. When I took the grate off the furnace grill, we found a group of mouse pellets. Looking inside there is large hole for electrical wires. On the other side of the hole is the basement behind the service station. Also found mouse pellets in the basement. I looked underneath the RV and there was a large hole near the service station.
As you can there is a very nice mouse trail up the water hose.
My solution was to cover that area with piece of plywood, build a little box on top and fill the box with steel wood. There is a plastic top to see the steel wool and later change it, if necessary. Now the mouse runs up the water hose and runs into a snug hole that is filled with steel wool if he can squeeze through. This steel wool mouse barrier is easy to install after hook up by passing the hose and cable through the snug holes in mouse barrier.
BTW. I looked at the service stations in a Cougar and Montana fifth wheels. Keystone actually has a barrier between the service station and the storage area, so if a mouse would get into that area, it could not get to the rest of the RV. Forrest River ought to consider a similar design
ID:	90224   Click image for larger version
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
Old 09-29-2015, 12:58 PM   #2
From what folks say, a copper Chore Boy is better to use than steel wool as it will not rust.
3 Copper Scouring Pad Tuff Copper Scrubber Heavy Duty 1 Pack of 3 New | eBay
Old 09-29-2015, 01:10 PM   #3
Flybob's Avatar
As a safety backup, get a bottle of "essential oil of peppermint" not peppermint oil used for cooking. Put 2-3 cotton balls in an old glass or coffee mug and add 3-4 drops of the peppermint oil. Mice and spiders hate it and it makes RV smell nice. Been doing this for years and no mice even though they are in garage a foot away. Do not get oil on surfaces as it is corrosive.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-29-2015, 05:06 PM   #4
Jeffco, MO
tedstr's Avatar
Thanks, OC, will change to copper in my little mouse nest.
Mary & Ted
modifications
