I'm going to bump this older post instead of starting a new on. Some nice info in here. And it shows that some people do actually search the forums.
I too want to make use of the area under my couch. I like what ILUVLCY did in post three. My couch & kick plate has three cushions, so cutting the kick plate in the middle would give the look of 4 cushions, with the middle two being smaller, if that makes sense.
I thought I'd start simpler. My kick plate is held in place by two upside down "J" hooks. That is it simply hangs off the upper bar that goes across the couch. There is nothing holding it at the bottom. I figure I can straighten those "J's" into "L's" and add a magnetic catch at the two lower corners (attached to the couch legs). This way the kick panel should just pop off with out having to lift up the couch.
My problem is that I also have the lower bar going across the opening. The top of this bar sits 2" off the floor and with the upper bar narrows the access space. I imagine that this bar was not put there just to support the drawer. Not even sure if that was an option on my 2017 2104S. I'd like to remove that bar, which would involve grinding down two little welds at each end (and probably a love tap or two). Can anyone think of a reason not to do such mod? Other than "don't remove stuff".
The legs are bolted directly to the floor. I would imagine the upper bar provides far more "triangulation" support than this lower bar. The couch appears to be completely independent of the Murphy bed and the side cabinets so mods should not affect bed operation. I can always add a support or two to the floor/side cabinets.
Funny how "keeping it simple" is becoming somewhat complicated.
Jim M.
