Old 08-04-2011, 07:48 PM   #31
Villa Estate 392FLFB
The_Stuff's Avatar
makes you want to do what "grampa did" and build your home with your own two hands!
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 08-04-2011, 09:32 PM   #32
Lol, yeah. I sure wish I had the time & place to have done this repair myself.
HomeGrown is offline   Reply With Quote
Old 08-15-2011, 08:12 PM   #33
A few more pics & updates on the trailer. New flooring is in throughout the trailer, and the super-sized bathroom is coming together. Should have the trailer back this week. Here's a few more pics (in various stages). The short cabinet will serve as a riser for the Splendide washer/dryer, and the converter was moved into this cabinet.
Old 08-15-2011, 10:21 PM   #34
jimh's Avatar
looking good. hard to believe it's the same trailer.
jimh is offline   Reply With Quote
Old 08-16-2011, 10:46 AM   #35
The_Stuff's Avatar
looking good indeed! hope they re-insulated the floor for you!
Old 08-16-2011, 08:48 PM   #36
Thanks guys... Nope Stuff, I couldn't afford to have them do it so it's something I'll most definitely take care of myself as soon as possible (will probably be a "next year" wish-list project).
Old 08-18-2011, 05:22 PM   #37
It may be easier to insulate before the floor goes down. That way you don't have to mess with the underlayment.
BTW : I have a FR Fema camper. I have used it for a deer season and a turkey season.
I added a water tank and pump and dump to a blue tank. When I am ready to go leave on Sunday evening I load the tank and generator and head out.
With 35+ nights and saving 15-20 80 mile trips I think I will save enough money to help offset the purchase price (2100).
I did find a soft spot in the bath room. It looks like it is grey water (soapy and no smell ). I have not found where it came from yet. It may have been an overflow in the bathtub.
It pooled in the underpayment. Last weekend I removed the sheeting and pulled out the wet insulation. This weekend I am going to run the water an see I can find a leak in the gray line coming from the sink.
I am planning on adding black and gray tanks and a RV toilet. First I am going to replace the whole floor in the bathroom. I could get by with just a 3X3 area but I think it would be easier to re-plumb and insulate with the floor out.
kanati is offline   Reply With Quote
Old 08-22-2011, 12:35 AM   #38
The_Stuff's Avatar
I have a question, the washer/dryer hookups.. did you just drill a hole through the floor for the drain? how about venting?
Old 08-27-2011, 08:20 PM   #39
Sorry Stuff, been away from the forum for a bit, been SO busy with getting the trailer back and putting stuff in it. To answer your questions, the drain plumbing runs under the riser the w/d is sitting on, so we just Tee'd into it with a 1 1/2" drain pipe coming up about 15". The dryer vent is installed directly in line with the outlet on the dryer, so it's a really direct & short vent.
Here's some new pics of the kitchen & W/D setup. in the second pic, the button on the side wall is for the garbage disposal. Also on that wall is the new digital t-stat. I ended up returning the 220v tankless water heater and getting a 10 gal. 110v unit instead. There seems to be plenty of hot water, but the water heater and w/d are on the same circuit and they don't like to share. I think my 50 amp conversion will be forthcoming in the next few weeks. As you can see from the pics, I still have a bit of trim work & caulking to finish up in the kitchen.
Old 08-28-2011, 03:39 PM   #40
The_Stuff's Avatar
wow ive never seen the waterheater mounted to the ceiling before lol! i got a stacker so im debating about running the vent down through the floor or out the wall.. thinking for winter what would be better...
looking good!
