Old 10-13-2015, 06:37 PM   #11
A32Deuce's Avatar
I removed the cover, made my connection then reattached the cover. It is a T type fitting. Doesn't take up much space.
A32Deuce is offline   Reply With Quote
Old 10-13-2015, 06:42 PM   #12
A32Deuce's Avatar
The cover is split. remove it and make the connection. Spread the cover and just place over the regulator leaving the connection uncovered.
Old 10-17-2015, 07:44 PM   #13
Stagecoachdriver, I like your bathroom mods, guess I need to buy a towel bar. We have a 2016 Sunseeker 2700DS and our lights over the dinette and couch are operated by pressing on the lens.
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 10-21-2015, 05:28 PM   #14
Sagecoachdriver's Avatar
More mods
Today I changed the single light switch for the Led lights above the sofa to two separate switches, one for each light. Similar to the ones above the dinette I posted earlier.
Also changed out the fixed temperature thermostat on the water heater to an Atwood adjustable thermostat. Instead of having scolding water coming out the shower at 140+ degrees, I have it adjusted down to around 117 degrees. This is what I had in my Winnebago and it worked out fine. Never had a problem with showers running out of hot water for just the DW and myself. Plus I will use the electric water heater mode prior to leaving on our trip which will also save on propane.
First photo is original Atwood thermostat installed. I remove it in the second photo and the third is the finished installing it.
Sorry, I tried to rotate them before the attachment, but I see it didn't work.
ID:	92430   Click image for larger version
ID:	92431   Click image for larger version
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 10-21-2015, 06:17 PM   #15
Here's a better photo of thermostat
Sorry, having issues with iPhone and iPad uploading photos to iMac . Haven't turned down temp as you can see in photo.
Old 10-23-2015, 03:31 PM   #16
Hatch to view fresh water tank
Because of a leak we had in fresh water filler hose by hose clamp (replaced with heavier duty hose), we no longer want to top off the tank where it pours out. There is no way using the tank level lights to get an accurate level. So I installed a hatch on the side bed frame giving me a visual of the tank. This also will allow me an accurate water level instead of thirds from the gauge.
Hatch also gives me easy access to the Schwintek Slide controller located just to the right on the floor. Easy to manual override if necessary and I don't have to remove the converter.
ID:	92644   Click image for larger version
ID:	92645   Click image for larger version
Old 10-23-2015, 05:28 PM   #17
Total Loss's Avatar
Good ideas.
Thanks guys.
Total Loss is offline   Reply With Quote
Old 10-23-2015, 06:11 PM   #18
Sagecoach, I'm still several months away from taking delivery but I'm thinking the hatch may be one of the first mods I make. Great idea!
newRVer is offline   Reply With Quote
Old 10-23-2015, 06:30 PM   #19
The hatch seemed like an obvious mod to access the Schwintek slide out controller. Otherwise, I would either have to remove all the bedding and the slide out would have to be totally out or remove the power panel and converter.
I added 3.5 gallons of water at a time and marked it on the tank and added an indication of quarters.
Old 10-24-2015, 12:40 AM   #20
benagi's Avatar
Dave you should be a design engineer for Forest River. Those are some nice and useful mods you're making.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
forester, modifications
