Old 05-20-2012, 03:23 PM   #1
RPAspey's Avatar
my fridge fans..
My little cube fan died. I really didn't feel like buying another for $16 just to have it die a year later. I built this for about $10 plus my time. It's held in place via velcro and ground clips. I had the wire, tin and fuse holder. Power is fed from the light switch. They only use about .28 A total. I was going to put a rheostat in the circuit to reduce fan speed, but determined it isn't necessary.
The only change I may make is to install fan guards to prevent anything from and jamming the fans.
ID:	14168   Click image for larger version
ID:	14169   Click image for larger version
ID:	14170   Click image for larger version
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-20-2012, 03:35 PM   #2
Thumbs up very nice
That is very well done.
rbrandon is offline   Reply With Quote
Old 05-20-2012, 06:48 PM   #3
J_KHawthorne's Avatar
What a beautiful piece of work!!!!!!!!!!!!
Do the twin fans give you a big improvement in performance? I already replaced the fan set-up behind my fridge, and if a fan in the fridge compartment itself makes for a big improvement in efficiency, maybe I should do that, too? What do you think???
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 05-20-2012, 07:07 PM   #4
RPAspey's Avatar
so far it's as good as my house fridge. keeps the temp around 35'. cools quickly. I can't hear the fans with the door close.
I want to do the coil fans next. I built a solar panel powered unit, self contained, but haven't installed it yet.
Old 05-20-2012, 08:17 PM   #5
Current River Rat
Be sure and post that one with photos when you do. And hurry up
Bruce & Sarah Tanner
Bttravel is offline   Reply With Quote
fan
